What is "Insertion Loss" (IL) in fiber optic connectors?
How much energy is lost when a signal passes through a connector? Why is it better for this metric to be as low as possible?
In fiber optics, Insertion Loss (IL) is a critical performance metric that quantifies the reduction in optical power resulting from the insertion of a component (such as a connector or a splice) into an optical fiber link.
1. How much energy is lost?
The amount of energy lost is typically expressed in decibels (dB). It is calculated using the following formula:
IL (dB) = -10 \log_{10} (P_{out} / P_{in})
Where:
  • P_{in} is the optical power before the connector.
  • P_{out} is the optical power after the connector.
For high-quality fiber optic connectors, a typical insertion loss value is 0.2 dB to 0.5 dB. To put this into perspective:
  • A loss of 0.3 dB means approximately 6.7% of the light power is lost.
  • A loss of 3.0 dB means 50% of the light power (half the signal) is lost.
2. Why must Insertion Loss be as low as possible?
Maintaining a low IL is essential for several technical reasons:
  • Signal Integrity and Link Budget: Every optical system has a “power budget”—the difference between the transmitter’s output power and the receiver’s sensitivity. If the cumulative IL from multiple connectors and components exceeds this budget, the receiver will not be able to detect the signal, leading to data errors or total system failure.
  • Transmission Distance: Higher loss weakens the signal faster as it travels. By minimizing IL at each connection point, the signal can travel much longer distances without requiring expensive optical amplifiers or repeaters.
  • Heat Dissipation in High-Power Systems: In high-power applications (such as fiber lasers or industrial sensing), the “lost” energy is often converted into heat. High IL in these scenarios can cause local overheating, which may damage the connector or the fiber end-face.
  • System Reliability: Low IL usually indicates high-quality physical alignment of the fiber cores (minimal lateral offset, angular misalignment, or longitudinal gaps). Connectors with low IL are generally more stable and reliable over time.
Related Technology in FBG Sensing
In Fiber Bragg Grating (FBG) sensing systems, managing insertion loss is vital because these systems often involve multiple sensors multiplexed on a single fiber string. Excessive IL at each connection or sensor point would limit the number of sensors that can be effectively monitored by a single OFSCN® Fiber Bragg Grating Interrogator.
For more detailed technical specifications on low-loss fiber components, you may refer to:
OFSCN® Fiber Optic Sensing Products
