How does it achieve micron-level precision alignment between two separate patch cords?
A fiber optic adapter, also known as a flange, achieves micron-level precision alignment between two separate patch cords primarily through the use of a high-precision alignment sleeve (also called a ceramic or metal sleeve) located inside the housing.
The process involves several critical engineering factors:
1. The Core Alignment Mechanism: The Alignment Sleeve
The heart of any adapter is the internal sleeve. For single-mode fibers, where the core is only about 9 micrometers in diameter, precision is vital.
- Material: Most high-quality adapters use Zirconia Ceramic sleeves. Zirconia is preferred because it is extremely hard, has high wear resistance, and maintains its shape under varying temperatures.
- Elasticity and Tight Fit: The sleeve is typically “split” (a split sleeve) to provide a degree of elasticity. When the ferrules of the two patch cords are inserted from both sides, the sleeve expands slightly and exerts a uniform radial force, centering the ferrules with high repeatability.
2. Precise Physical Contact (PC/APC)
The alignment is not just about lateral positioning but also longitudinal contact.
- Ferrule Geometry: The connectors on the patch cords (like the OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord) feature ceramic ferrules with precisely polished end-faces.
- Spring Loading: Inside the connector housing, a spring pushes the ferrule forward. When inserted into the adapter, the springs ensure that the two ferrule faces are pressed together with a specific force, eliminating any air gap and minimizing insertion loss.
3. Mechanical Housing and Keying
To prevent the fiber cores from rotating or being misaligned during connection:
- Keyway System: Connectors like the FC/APC (common in OFSCN® products) use a mechanical key and slot. This ensures the connector can only be inserted in one orientation, which is crucial for APC (Angled Physical Contact) connectors to ensure the 8-degree angles match perfectly.
- Rigid Body: The outer shell of the adapter (the flange) provides the mechanical stability to hold the patch cords securely in place against vibration or pulling forces.
Related Products
In high-precision sensing applications, such as those using OFSCN® Fiber Bragg Grating (FBG) Temperature Sensors or OFSCN® Fiber Bragg Grating Interrogators, the quality of the adapter is critical to maintaining signal integrity and measurement accuracy.
If you are setting up a sensing system, ensuring that your patch cords (like the OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord) match the adapter type (e.g., FC/APC to FC/APC) is essential for achieving the precision you mentioned.
