Faced with hundreds of models, how can beginners choose the right jumper in three steps?
In optical engineering and sensor system deployment, faced with a plethora of fiber optic patch cord specifications, engineers typically employ the “Three-Step Positioning Method” to quickly identify the patch cord specifications that meet system requirements:
Step 1: Determine Optical Characteristics and Fiber Type (Core Physical Layer)
First, match the optical path transmission mode of the system’s light source, detector, or sensor:
- Transmission Mode:
- Single-Mode Fiber (SM): Used for long-distance communication, fiber optic sensing (e.g., FBG fiber grating interrogators). Standard core diameter is typically 8 \sim 10\ \mu\text{m} (e.g., G.652D or G.657 fiber with a smaller bend radius).
- Multi-Mode Fiber (MM): Used for short-distance high-bandwidth communication or specific spectral collection systems (core diameter is generally 50\ \mu\text{m} or 62.5\ \mu\text{m}).
- Polarization-Maintaining Fiber (PM): Used in precision optical systems sensitive to polarization states, such as fiber optic gyroscopes and interferometers.
Step 2: Determine Connector Type and Ferrule Polishing Method (Interface Matching Layer)
Confirm the physical interfaces of the devices being connected at both ends (e.g., interrogator flange, sensor output lead):
- Connector Physical Structure:
- FC (Round head with screw lock, good vibration resistance, often used for test instruments and sensor systems).
- LC (Small form factor, tab-and-latch, commonly used for high-density cabling).
- SC (Standard square push-pull, commonly used for communication equipment).
- ST (Round head with bayonet lock).
- Ferrule Polishing Angle:
- PC / UPC (Flat/Ultra Physical Contact polish, return loss typically \le -50\text{dB}).
- APC (8-degree Angled Physical Contact polish, return loss better than -60\text{dB}, which can minimize the interference of reflected light on precision narrow linewidth lasers or interrogation modules. Fiber Bragg Grating sensing systems typically default to FC/APC connectors).
Step 3: Determine Usage Environment and Mechanical Protection Level (Environmental Adaptation Layer)
Select the patch cord’s armor and jacket structure based on the on-site temperature, tensile force, pressure, and corrosiveness of the deployment environment:
- Standard Indoor and Data Center Environments:
Use lightweight standard patch cords with a PVC outer jacket and aramid tensile fibers.- Reference Specification: OFSCN® Standard Fiber Patch Cord
- Operating Temperature: -20^\circ\text{C} to 50^\circ\text{C}.
- Harsh Industrial and High Mechanical Load Environments (Crush Resistance, Tensile Strength, Rodent Resistance):
Requires patch cords with micro-armor or steel wire rope armor.- Micro Steel Tube Armored: Such as OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord, featuring a 0.6\text{mm} seamless stainless steel tube inside, offering both flexibility and wear resistance.
- Steel Wire Rope Armored (Heavy Duty): Such as OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord and OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord (Tensile strength >1200\text{N}, compressive strength >200\text{MPa}).
- Extreme Temperature Environments (Cryogenic or Ultra-High Temperature Applications):
Standard polymer jackets can age and crack at high temperatures. Metal-tube encapsulation and high-temperature resistant coated fibers are required:- Temperature Resistance 120^\circ\text{C}: OFSCN® 120℃ Fiber Optic Patch Cord (High-temperature polyacrylate fiber).
- Temperature Resistance 200^\circ\text{C} \sim 300^\circ\text{C}: OFSCN® 200℃ Fiber Optic Patch Cord, OFSCN® 300℃ Fiber Optic Patch Cord (Polyimide-coated fiber, covering a temperature range of -270^\circ\text{C} \sim 300^\circ\text{C}).
- Temperature Resistance 700^\circ\text{C}: OFSCN® 700℃ Fiber Optic Patch Cord (Gold-plated fiber with seamless steel tube construction).
Selection Summary Logic
[1. Optical Match]: SM / MM / PM + Core Spec
[2. Interface Match]: FC / SC / LC / ST + PC / APC
[3. Environmental Match]: Standard PVC / Micro Armor / Steel Wire Rope / High-Temp Metal Tube + Length
For more technical specifications on the patch cord series, please refer to: OFSCN® Fiber Optic Patch Cord Product Classification.
