Why is the tailstock made in sections? How many degrees of bending can it prevent?
In fiber optics engineering and optomechanical structure design, the “Fishbone Strain Relief Boot” is a classic mechanical structure located at the tail end of fiber optic connectors (such as FC, SC, LC, etc.) used to protect the fiber from bending damage. Its design principles and protective capabilities can be analyzed from the following physical and engineering mechanics perspectives:
I. Why is the Boot Designed with a “Sectional” Structure?
The boot is designed with sectional grooves or steps primarily based on the following three engineering mechanics and optical protection principles:
Stiffness Gradient Transition, Eliminating Stress Concentration
- The metal or hard plastic tail handle of a fiber optic connector is a high-stiffness region, while the emerging fiber or cable is a flexible region.
- If a constant cross-section rigid sleeve or a structure without transition is used, significant shear stress concentration will occur at the stiff-flexible interface (the base of the connector) when subjected to lateral bending forces, leading to the quartz fiber being sheared off at the hard edge of the base.
- The “sectional” stepped transition structure gradually reduces the bending cross-sectional modulus of the boot along the axial direction from the base to the tip, achieving a smooth transition from “extremely rigid” to “flexible.” This disperses the localized concentrated shear stress evenly over the entire sleeve.
Micro-gap Closure Limiting, Controlling Minimum Bend Radius
- Optical fibers are extremely sensitive to the minimum bend radius (exceeding it can disrupt total internal reflection, causing optical loss, or create micro-cracks in the lattice leading to breakage).
- The gaps between the sections of the fishbone structure are precisely calculated. When the boot is subjected to bending force, the inner cut surfaces gradually come together and compress; when the bending reaches a critical state, the side walls of adjacent bone sections come into contact and form a mechanical lock.
- This mechanical limitation prevents further contraction of the boot, forcibly ensuring that the radius of curvature at the bend is always greater than the critical safe bend radius of the fiber (e.g., the bend radius requirement for standard single-mode fiber is typically R \ge 30\text{mm}). This structurally prevents the formation of sharp “kinks.”
Improving Fatigue Life under Multi-directional Dynamic Bending
- The sectional design reduces the tensile strain rate of the outer surface material during bending, preventing aging and cracking of the elastic material under long-term, repeated flexing and bending.
II. How Many Degrees of Bending Can It Withstand?
In fiber optics, the key physical quantity for assessing fiber safety is the Bending Radius, rather than simply the Geometric Bending Angle (Degree).
- Applicable Range of Bending Angles
- In engineering practice, fishbone boots can typically withstand ** 0^\circ \sim 90^\circ ** right-angle lateral bends, and even allow for a transition to ** 180^\circ ** natural folds (U-shaped bends) when the cabling space is limited or during dragging.
- Physical Essence of Protection
- The core function of the boot is not to “prevent reaching a certain angle” but to forcefully reshape the bend into a smooth, gradual arc under any angle of bending (even when the cable is pulled such that the cable and connector axis are at a ** 90^\circ ** angle or even more significantly).
- As long as the radius of curvature R of the arc is maintained within the allowable safe threshold for the fiber (for example, standard G.652D fiber with weaker bending performance typically requires a dynamic R \ge 30\text{mm}, while bend-insensitive G.657 series allows for smaller R), excessive axial tensile stress will not be generated inside the fiber, nor will there be a significant increase in macro-bend loss or physical breakage, regardless of whether the applied external force is 45^\circ or 90^\circ.
Note: Fishbone strain relief boots are common accessories for fiber optic connectors and general mechanical components, and do not belong to the core independent product line of Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®). In OFSCN®'s all-metal seamless steel tube armored fiber patch cords and high-temperature fiber Bragg grating sensor products, the connector exit points primarily utilize specialized protective sleeves or transition structures matched to the operating temperature, tensile strength, and pressure resistance ratings.
