What is a "mechanical reliability model"?
How can we predict that a jumper wire will last 20 years under specific pressure?
In fiber optics engineering and material mechanics, predicting the service life (e.g., 20 or 25 years) of optical fibers or patch cords under long-term loads such as tension, lateral pressure, or bending stress relies on the Optical Fiber Mechanical Reliability Model.
This model is primarily based on Fracture Mechanics, Subcritical Crack Growth theory, and Weibull Statistics, and has been standardized into international standards (such as IEC 60793-1-33, ITU-T G.650, etc.).
The specific calculation and engineering assessment process to predict whether a patch cord can stably operate for 20 years under a specific long-term stress/pressure is as follows:
I. Physical Failure Mechanism: Stress Corrosion and Slow Crack Growth
The fiber core material is silica (\text{SiO}_2) glass, which is a brittle material. Its mechanical failure follows brittle fracture mechanics:
  1. The glass surface inevitably has sub-micron to nano-scale subsurface cracks (Griffith cracks).
  2. Under the synergistic action of tensile stress \sigma and environmental moisture/water vapor ( \text{OH}^- ), the bond at the crack tip undergoes a stress corrosion chemical hydrolysis reaction:
    \text{Si-O-Si} + \text{H}_2\text{O} \longrightarrow 2\text{Si-OH}
  3. The crack grows slowly (subcritical crack growth) until the stress intensity factor reaches the critical fracture toughness K_{IC}, leading to sudden brittle fracture.
The crack growth rate follows a power-law empirical equation (Power-law fatigue model):
v = \frac{da}{dt} = A K_I^n
Where:
  • a is the crack depth;
  • K_I is the stress intensity factor ( K_I = Y \sigma \sqrt{a} );
  • n is the Stress Corrosion Susceptibility Parameter, which reflects the material’s ability to resist environmental stress fatigue aging (in ambient humid conditions, standard silica fibers typically have n \approx 18 \sim 24 );
  • A is an environmental constant.
II. Static Fatigue Lifetime Prediction Model (IEC 60793-1-33)
Before leaving the factory, fibers typically undergo proof testing, applying a proof stress \sigma_p (standard value usually 100\ \text{kpsi} \approx 0.7\ \text{GPa}, corresponding to a strain of about 1\% ), which short-term ( \sim 1\ \text{s} ) eliminates all cracks larger than a critical size.
1. Constant Load Lifetime Equation
For fibers that have passed the proof test under proof stress \sigma_p along their entire length, the minimum time to fracture t_f under long-term constant operating stress \sigma_a follows:
t_f = \frac{B \cdot \sigma_p^{n-2}}{\sigma_a^n}
Where B is a crack growth constant.
According to IEC/ITU reliability specifications, if a fiber is required to have a high reliability lifetime of 20 years ( t \approx 6.3 \times 10^8\ \text{s} ) or longer under constant stress (failure rate F < 10^{-5} ), the sustained tensile stress \sigma_a that the fiber can withstand internally must be strictly controlled within the safe threshold of the proof stress:
\frac{\sigma_a}{\sigma_p} \le 0.20 \sim 0.33
This means the continuous equivalent stress experienced by the fiber surface typically should not exceed approximately 140 \sim 230\ \text{MPa} (corresponding to a strain of about 0.2\% \sim 0.3\% ).
III. Prediction Steps from “External Pressure” to “Internal Fiber Stress”
The “specific pressure” experienced by a patch cord typically manifests as external lateral load/crush load or hydrostatic pressure. Silica glass itself has extremely high compressive strength (theoretical pure compressive strength greater than 5\ \text{GPa} ), so fractures of patch cords under lateral pressure are almost entirely caused by local tensile stress induced by the deformation of the jacket squeezing the fiber, resulting in local shear and bending.
The specific steps to predict a 20-year lifetime are as follows:
Step 1: Structural Elasticity and Deformation Analysis of the Cable Jacket (FEA / Elastic Mechanics)
Establish a stress model for the outer structure of the patch cord and calculate the deformation of the outer protective layer (e.g., metal armor tube, steel wire layer) under a specific lateral load (e.g., P ):
  • Assess the yield strength of the armor material. If the external pressure is below the material’s long-term creep/yield limit, the radial deformation of the armor layer will be rigidly constrained.
  • Ensure the internal gap is larger than the deformation of the outer tube under pressure, shielding the vast majority of the lateral pressure onto the metal armor layer and preventing direct compression of the bare fiber.
Step 2: Extract Maximum Tensile Strain \varepsilon_{\max} on the Internal Fiber
If the external pressure causes slight elastic deformation of the tube and it contacts the fiber, or if local micro-bending occurs, the maximum tensile stress on the fiber surface needs to be calculated using elastic contact mechanics:
\sigma_{\max} = E \cdot \varepsilon_{\max}
Where E is the Young’s modulus of the fiber (for quartz glass, E \approx 72\ \text{GPa} ).
Step 3: Substitute into Dynamic/Static Lifetime and Failure Rate Equations
Use the calculated working stress \sigma_{\max} as \sigma_a, and select the appropriate stress corrosion parameter n and Weibull failure rate F based on the actual application environment’s temperature and humidity:
t_{\text{service}} = t_p \left( \frac{\sigma_p}{\sigma_a} \right)^n \left[ \frac{\ln(1 - F)}{-L \cdot N_p} \right]^{\frac{n-2}{m}}
Verify through this formula whether the cumulative failure rate F is below the engineering allowable index (e.g., 10^{-4} or 10^{-6} ) within the given 20-year ( 6.3 \times 10^8\ \text{s} ) period.
IV. Fiber Optic Patch Cord Solutions for High Lateral Pressure Engineering Environments
Ordinary polymer-jacketed patch cords have extremely low resistance to lateral pressure. Continuous pressure will cause jacket creep and subsequently crack the fiber. In industrial and civil applications requiring high lateral pressure resistance and long-term reliability, high-rigidity metal jacketing must be used to completely decouple the pressure from the fiber.
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) offers a series of all-metal and armored patch cords with extremely high compressive strength:
