What is an optical circulator?
How does it make light travel in only one direction and not go back?
An optical circulator is a multi-port, non-reciprocal optical device. It’s important to note that optical circulators are not part of OFSCN®'s core product line. However, as a fundamental component in optical engineering, its physical principle of “allowing light to travel in only one direction (e.g., from Port 1 to Port 2, and Port 2 to Port 3) without reflection” is highly classic.
At the heart of this characteristic is the realization of Optical Non-reciprocity, with the Faraday Effect being the underlying physical mechanism.
I. Core Physical Mechanism: Non-reciprocal Faraday Rotation
In ordinary optical media (such as common glass, optical fibers, or waveplates), light paths are reciprocal. If a light beam’s polarization plane rotates clockwise by 45^\circ when passing through a waveplate, it will rotate counter-clockwise by 45^\circ when retracing its path through the same waveplate, returning the polarization state to its initial condition. This does not enable unidirectional propagation.
Optical circulators leverage the Faraday Effect (Magneto-Optical Effect):
  1. Magneto-Optical Crystal: The circulator contains a special magneto-optical crystal (e.g., Yttrium Iron Garnet, YIG) and is subjected to a strong, constant external magnetic field.
  2. Non-reciprocal Rotation: When linearly polarized light passes through the magneto-optical crystal in the presence of an external magnetic field, its polarization plane rotates. Crucially, the direction of rotation is solely determined by the direction of the applied magnetic field and is independent of the direction of light propagation (forward or backward).
  3. If a Faraday rotator is designed to rotate the polarization plane of passing light by 45^\circ :
    • Forward Pass: The polarization plane rotates by +45^\circ .
    • Backward Pass: The polarization plane still rotates by +45^\circ (from the perspective of the same observer, the rotation direction does not reverse but continues to accumulate).
    • Result: Light passing forward and then backward accumulates a total polarization rotation of 90^\circ , rather than canceling out as it would in ordinary media.
II. Internal Working Principle of Polarization-Independent Optical Circulators
Commercially used optical circulators are typically Polarization Independent. Their internal structure mainly comprises a combination of birefringent walk-off crystals (e.g., YVO_4 crystals), a Faraday Rotator, and a Half-Wave Plate.
Taking a three-port circulator (Port 1, Port 2, Port 3) as an example, its specific light path control is as follows:
1. Light from Port 1 \to Port 2 (Forward Propagation)
  • Beam Splitting: Light entering from Port 1 first passes through the first birefringent crystal, where it is split into two beams with orthogonal polarization directions: ordinary light (o-light) and extraordinary light (e-light). These beams experience a slight spatial walk-off (separation).
  • Rotation Cancellation: These two beams then pass through a Faraday rotator (which rotates the polarization by +45^\circ ) and a specific half-wave plate (whose optical axis is designed to rotate the polarization of the forward light by -45^\circ ).
  • Through their combined action, the total rotation angle is +45^\circ + (-45^\circ) = 0^\circ . The polarization state of the light remains unchanged after passing through these two components.
  • Beam Combination: Since the polarization state has not changed, when the two beams reach the second birefringent crystal, its beam-splitting and recombination properties are complementary to the first crystal. The o-light and e-light recombine spatially and are precisely focused and coupled into Port 2.
2. Light from Port 2 \to Port 3 (Backward Isolation and Redirection)
  • If light enters in the reverse direction from Port 2, it is first split again into o-light and e-light by the second birefringent crystal.
  • Rotation Accumulation: When passing backward through the half-wave plate, the polarization rotates by -45^\circ ; however, due to the non-reciprocity of the Faraday rotator, it still rotates by +45^\circ when passing through it in the backward direction (in the opposite geometric reference frame, this effectively adds in the same direction as the half-wave plate’s rotation).
  • Through their combined action, the total rotation angle reaches 90^\circ .
  • Polarization Swapping and Walk-off: A 90^\circ rotation causes the original o-light to become e-light and the original e-light to become o-light.
  • Redirection: When these two beams with swapped polarization states reach the first birefringent crystal, the crystal’s polarization modulation direction for them is reversed (the walk-off direction is opposite). These two beams not only fail to recombine at the location of Port 1 but are also deviated from the fiber core of Port 1. They recombine at a different specific spatial location and are finally precisely guided and coupled into Port 3.
Summary
Optical circulators achieve unidirectional light wave transmission by combining the non-reciprocal Faraday rotator with the reciprocal half-wave plate. This causes the polarization states of forward and backward propagating light to change differently. Subsequently, birefringent crystals are used to spatially split and combine beams of different polarizations, thereby realizing the unidirectional circulation of light waves.
