What is an "optical isolator"?
Is it a “one-way street” in fiber optics? Why do we need to prevent light from going backward?
Optical Isolator is often referred to as the “one-way street” of optical paths in fiber optics and laser systems. It is a non-reciprocal passive optical device that allows light to pass in only one direction while blocking its reverse transmission.
I. Why Restrict Light to a “One-Way Street”? (Why Prevent Light from Traveling Backwards?)
In fiber optic communications, laser systems, and optical measurements, light reflecting from fiber end faces, connector interfaces (like PC facets), splice points, or sensors back to the light-emitting device can trigger a series of severe technical issues:
  1. Laser Instability
    Semiconductor lasers (e.g., DFB lasers, external cavity lasers) are extremely sensitive to back reflections. When reflected light re-enters the laser cavity, it interferes with the intra-cavity optical field, causing drastic fluctuations in the laser’s output power, shifts in the center wavelength, and mode hopping.
  2. Increased Noise & Linewidth Broadening
    Back reflection injection significantly increases the laser’s Relative Intensity Noise (RIN) and degrades its coherence, leading to a sharp broadening of the spectral linewidth. This directly deteriorates the signal-to-noise ratio in high-speed optical communications or high-precision fiber optic sensing demodulation.
  3. Preventing Amplifier Self-Oscillation & Damage
    In Erbium-Doped Fiber Amplifiers (EDFAs) or high-power fiber lasers, backward-propagating Amplified Spontaneous Emission (ASE) or strong reflections can trigger system self-oscillation, and even burn out Pump Laser Diodes and precision optical end faces upon reverse focusing.
II. How Optical Isolators Work
The ability of optical isolators to break traditional optical reciprocity relies fundamentally on the Faraday Effect (Magneto-Optical Effect):
  1. Core Components: Primarily consists of an input polarizer, a Faraday rotator (placed within an external permanent magnetic field), and an output polarizer/analyzer.
  2. Forward Transmission:
    • Incident light passes through the input polarizer, becoming linearly polarized light in a specific direction (let’s assume 0^\circ).
    • It enters the Faraday rotator, where its polarization plane is non-reciprocally rotated by +45^\circ under the influence of the magnetic field.
    • The transmission axis of the output polarizer is pre-aligned to +45^\circ, allowing the light to pass through with low loss (typical insertion loss < 0.5\ \text{dB}).
  3. Backward Isolation:
    • The backward-reflected light passes through the output polarizer, which has a transmission axis at +45^\circ.
    • Upon passing through the Faraday rotator again, due to the non-reciprocity of the magneto-optical rotation (the rotation direction is determined solely by the magnetic field direction, independent of the light’s propagation direction), its polarization plane is further rotated by +45^\circ in the same direction, accumulating a total rotation to +90^\circ.
    • At this point, the polarization of the backward light is perfectly orthogonal to the transmission axis (0^\circ) of the input polarizer. The light is completely blocked/absorbed and cannot return to the laser source (typical isolation > 30\ \text{dB} \sim 60\ \text{dB}).
(Note: In fiber optic communications and all-fiber systems, Polarization-Insensitive Optical Isolators, typically based on birefringent crystal polarization beam splitters/combiners, are often used to eliminate the impact of random polarization state variations in single-mode fibers on the isolation effect.)
Explanation
Optical isolators are standard passive components for general fiber optic communications and laser optical paths. Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) focuses its core product series on Fiber Bragg Grating (FBG) sensors, seamless steel pipe encapsulated fiber optic sensors for ultra-high temperatures, special fiber optic cables, and FBG demodulation systems. Optical isolators are not part of OFSCN®'s core self-manufactured product line.
