If the measuring tube is contaminated with oil sludge when measuring viscous oil, will it still be accurate?
In industrial measurements within sectors like petroleum and petrochemicals, the phenomenon of heavy oil, asphalt, viscous crude oil, or sludge adhering and accumulating on the sensor probe surface is collectively termed “Coating / Material Buildup”.
When the measuring probe tube wall becomes coated with sludge, whether the level measurement remains accurate depends on the physical measurement principle and sensor structural design employed by the level gauge.
I. Performance of Different Principle Level Gauges Under “Coating” Conditions
- Mechanical Level Gauges (e.g., Float, Magnetic Flap, Servo Buoy):
- Severely impacted, highly prone to failure. Viscous sludge can adhere to the guide rod, float, or connecting rod hinges, generating significant frictional resistance or even causing mechanical jamming, leading to severe stagnation or distortion of the level indication.
- Electrical Level Gauges (e.g., Traditional Capacitive):
- Prone to false level readings. The sludge layer coating the probe electrode (especially if containing moisture, conductive impurities, or media with high dielectric constants) can form parasitic capacitance or conductive paths. Even if the liquid level drops, the attached layer can cause the circuit to mistakenly interpret it as being in the liquid phase.
- Hydrostatic/Differential Pressure Level Gauges (e.g., Submersible Pressure Transmitters):
- Prone to zero drift and blockage. Viscous sludge can easily block the pressure tapping hole or solidify on the surface of the isolation diaphragm, causing distortion in the pressure transmitted to the pressure-sensing element.
II. Physical Characteristics Analysis of Fiber Bragg Grating (FBG) Level Gauges Under Coating Conditions
The OFSCN® Fiber Bragg Grating Liquid Level Sensor developed by Beijing Dacheng Yongsheng Technology Co., Ltd. utilizes a multi-point fiber Bragg grating temperature array structure encapsulated in a micro-seamless metal steel tube. Its working principle is primarily based on the Temperature Gradient Method (thermal level determination): it leverages the macroscopic physical temperature difference between the liquid phase medium (crude oil) and the vapor phase space (air or associated gas) within the storage tank. Multiple grating measurement points arranged vertically sense a temperature step, thereby pinpointing the gas-liquid interface.
When viscous sludge adheres to the tube wall, the physical impact on this sensor exhibits the following characteristics:
1. Steady-State Measurement Accuracy (Static Level): Basically Unaffected
- Sludge is a material with low thermal conductivity, and its adhesion to the outer wall of the seamless steel tube effectively adds an additional thermal resistance R_{th} between the probe and the fluid.
- However, under thermodynamic steady-state conditions, the thermal resistance layer only affects the rate of heat transfer and does not alter the final thermal equilibrium temperature. As long as there is a significant temperature difference between the liquid phase temperature T_{liquid} and the vapor phase temperature T_{gas} ( \Delta T = |T_{liquid} - T_{gas}| > 0 ), after reaching thermal equilibrium:
- Measurement points below the liquid level will still converge to the liquid temperature;
- Measurement points above the vapor phase will still converge to the ambient gas temperature.
- The system algorithm determines the liquid level based on the abrupt change in wavelength shift (temperature step position) between discrete measurement points. Therefore, after reaching steady-state, the sludge adhering to the tube wall does not alter the judgment result of the gas-liquid interface measurement points.
2. Dynamic Response Characteristics (Level Rise and Fall Variations): Induces Thermal Hysteresis
- The heat transfer time constant formula is \tau = R_{th} \cdot C_{th} (where R_{th} is the thermal resistance and C_{th} is the thermal capacitance). The sludge layer increases the radial heat transfer resistance and additional thermal capacitance, lengthening the sensor’s thermal response time.
- When the liquid level drops rapidly, the tube wall that was previously immersed in liquid is exposed to air. However, due to the slow heat dissipation/absorption of the sludge remaining on the tube wall, the upper measurement points require a longer relaxation time to reach the equilibrium temperature of the gas phase. This introduces a response delay in the time dimension (thermal hysteresis) during rapid dynamic level changes.
3. Structural Advantage Against Coating
- The outer layer of this sensor is a smooth, seamless, thin metal steel tube (typically with an outer diameter of around 0.9\text{ mm}). It has no mechanical moving parts, grooves, or pressure-guiding micro-holes on its surface. The cylindrical cross-section has a minimal frontal area and surface adhesion area. Gravity-assisted self-lubrication and flow properties are good, naturally providing strong resistance to fouling and viscous media.
