What is the jumper selection for "level gauges"?
In viscous liquids, how is the encapsulated tube surface treated to prevent false positives from material buildup?
In environments with viscous liquids (such as heavy oil, resin, high-viscosity slurries, etc.), if a Fiber Bragg Grating liquid level sensor relies on the principle of temperature gradient to determine the liquid level, the residual material (clingage film) on the outer wall of the metal encapsulated tube during liquid level decrease will cause a delay in the temperature change of the measuring point exposed to the gas phase due to the thermal resistance and heat capacity lag effect, thereby triggering false alarms in the demodulation system.
For such working conditions, the surface treatment of the encapsulated tube and the engineering anti-clingage solutions primarily address the issue from four dimensions: Interface Chemical Modification, Microscopic Morphology Control, Geometric Dimension Optimization, and Algorithmic Transient Recognition:
1. Surface Chemical Modification: Low Surface Energy Oleophobic/Anti-Adhesion Coatings
By preparing a low surface free energy coating on the outer wall of the encapsulated tube, the contact angle (\\theta) between the liquid and the tube wall is increased, disrupting the wetting and spreading conditions of viscous media on the metal surface:
  • Teflon-type Coatings (PTFE / FEP / PFA): Possess extremely low surface free energy (typically < 20\ \text{mN/m}) and exhibit excellent anti-adhesion, chemical corrosion resistance, and high-temperature resistance. Media on the tube wall easily form spherical droplets and rapidly slide off under gravity, preventing the formation of a continuous viscous film.
  • Super-oleophobic / Super-hydrophobic Nanocomposite Coatings: For specific polar or non-polar viscous liquids, siloxane-based or fluorinated nanocomposite coatings are used to construct micro-nano rough structures, reducing the actual solid-liquid contact area and significantly lowering the adhesion work of droplets.
2. Microscopic Morphology Control: Ultra-fine Mechanical Grinding and Electropolishing (EP)
Encapsulated tube substrates are typically made of 316L stainless steel or elastic alloy tubes. Untreated tube surfaces have microscopic pits and scratches, which can lead to capillary adhesion effects:
  • Electropolishing (Electropolishing): Eliminates microscopic rough protrusions through electrochemical anodic dissolution, reducing the outer surface roughness to a mirror finish level of Ra \le 0.2\ \mu\text{m} or even Ra \le 0.1\ \mu\text{m}. The extremely low microscopic roughness not only removes mechanical interlocking sites for clingage but also significantly reduces the boundary resistance of medium flow, accelerating the self-weight detachment of the liquid material.
3. Geometric Outer Diameter Miniaturization (Reducing Cross-sectional Area and Clingage Thickness)
The amount of residual liquid that the surface tension of the liquid material can suspend is directly proportional to the cross-sectional circumference and the force-bearing area of the encapsulated tube:
  • Using a seamless stainless steel tube structure with a reduced outer diameter can significantly decrease the adhesion mass of single-point liquids. The smaller the outer diameter, the weaker the capillary adsorption capacity, the thinner the residual liquid film, and the exponentially shorter the thermal time constant \tau.
  • OFSCN® Fiber Bragg Grating Liquid Level Sensor employs seamless steel tube encapsulation technology. The standard outer diameter of the sensor is 0.9\text{mm}, and it can be customized to a fine outer diameter structure as small as 0.5\text{mm} according to engineering requirements, effectively reducing the accumulation of heavy viscous liquids.
OFSCN® 300°C Fiber Bragging Grating Temperature Sensor
4. Demodulation End Algorithm: Dynamic Temperature Rate of Change (dT/dt) and Thermal Relaxation Feature Recognition
When physical anti-clingage measures still leave a small amount of residue, transient temperature response recognition can be supplemented at the demodulation software level:
  • Real Liquid Level Variation: During interface transition, the medium switches from liquid to gas phase, causing a step change in thermal conductivity. The transient derivative of the temperature sensor’s response rate \left| \frac{dT}{dt} \right| exhibits a sharp peak.
  • Clingage Residue Cooling: Evaporation and heat dissipation of the residual thin film on the surface follow a continuous exponential decay (relaxation curve) in accordance with Newton’s law of cooling, with a significantly gentler change in slope. By setting a differential slope threshold and a steady-state holding time criterion, transient false triggers during the clingage process can be accurately filtered out.
