How can I verify if the OFSCN® patch cords I purchased are genuine original factory products?
To identify whether a fiber optic patch cord is an original OFSCN® product manufactured by Beijing Dacheng Yongsheng Technology Co., Ltd. (Beijing Dacheng Yongsheng Technology Co., Ltd.), you can compare and distinguish it across four technical dimensions: internal physical structural characteristics, temperature and material properties, optical performance testing, and official factory traceability:
I. Physical Structure and Armoring Process Characteristics (Most Intuitive Identification Features)
Most conventional commercial communication fiber optic patch cords use a simple structure of “outer jacket + aramid yarn (Kevlar) + tight-buffered fiber”; whereas OFSCN® industrial-grade and specialty patch cords commonly employ seamless steel tube and metal stranded armoring technology:
- Micro-Steel Armored Seamless Tube Structure:
- For example, OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord, its jacket encapsulates a precision seamless stainless steel tube with an outer diameter of 0.6\ \text{mm}. This provides extremely high resistance to side pressure (compressive strength > 240\ \text{MPa}) and protection against rodent damage and foot traffic. It feels rigid when squeezed by hand, clearly differentiating it from ordinary soft patch cords.
- Steel Wire Rope Stranded Armoring Structure:
- For example, OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord and OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord, which integrate micro steel wire ropes and seamless steel tubes internally. The tensile strength can reach 1200\ \text{N} to 1500\ \text{N}, representing a full metal mechanical protection structure.
II. Specialty Fiber Material and Coating Layer Identification (for High-Temperature Series)
If you are purchasing OFSCN® high-temperature resistant specialty patch cords, the fiber material itself differs significantly from conventional single-mode/multi-mode fibers:
- Conventional Communication Fiber (Normal Temperature ~ 85℃):
- Uses a standard acrylate coating layer, with a typical fiber coating outer diameter of 245\ \mu\text{m} \sim 255\ \mu\text{m}.
- High-Temperature 300℃ Patch Cord:
- For instance, OFSCN® 300℃ Fiber Optic Patch Cord, employs high-temperature resistant polyimide-coated fiber. The coating layer has a distinctive amber/golden hue, and the coating outer diameter is generally 155\ \mu\text{m}. The patch cord body is typically a 0.9\ \text{mm} seamless stainless steel bare metal tube.
- High-Temperature 700℃ Patch Cord:
- As seen in OFSCN® 700℃ Fiber Optic Patch Cord, the fiber surface features a true high-temperature resistant gold-plated metal layer (Gold-coated). The bare fiber strand appears metallic gold.
III. Fiber Optic Connector Process and Optical Specifications
- Precision Grinding of Fiber Optic Connectors:
- Original factory standard connectors (commonly FC/APC, FC/PC, ST, etc.) use high-precision ceramic ferrules, with end faces processed by industrial-grade grinding machines.
- For APC connectors, there is a strictly precise 8^\circ angle polish. The end face should be free of scratches and pits, ensuring high Return Loss (RL), typically \text{RL} \ge 60\ \text{dB}.
- Optical Loss Consistency:
- Using a light source and power meter to measure Insertion Loss (IL). Original factory patch cords typically have a typical loss of \text{IL} \le 0.3\ \text{dB} (single-mode).
IV. Packaging, Technical Documents, and Official Verification
- Factory Calibration and Test Records:
- OFSCN® original factory patch cords and sensors are accompanied by factory quality inspection labels or relevant technical specification parameter sheets.
- Official Traceability Verification:
- Beijing Dacheng Yongsheng Technology Co., Ltd. provides official traceability verification services. If you have doubts about the authenticity of a product, please record the patch cord’s specifications, batch information, and send it to the official email for factory data comparison and verification:
- Official Technical Support and Verification Email:
dcys@ofscn.com - Official Product Catalog Reference: OFSCN® Fiber Optic Patch Cord Product Catalog
