What is a factory test report?
Does every jumper have its own “identity card” and performance data?
In industrial-grade optical fiber communication and fiber optic sensing engineering, qualified Fiber Optic Patch Cords and fiber optic sensors are typically equipped with a dedicated Factory Test Report, and each patch cord is associated with its physical product through a unique identification number (Product Serial Number / SN code), establishing a mapping relationship between the physical product and its test data (the so-called “ID card”).
I. What is a “Factory Test Report” and the Function of its “ID Card”
A Factory Test Report is the authoritative quality certificate for fiber optic patch cords or sensors, generated after completion of assembly, polishing, and encapsulation processes. It documents the core optical and physical performance indicators as determined by professional instruments and equipment.
  1. “ID Card” (Unique Serial Number SN)
    • Each fiber optic patch cord is imprinted with a unique identification code on its label or sleeve during final production inspection.
    • Function: Used for quality traceability throughout its entire lifecycle, on-site test data alignment, and parameter import during system integration and debugging.
  2. Core Performance Data Content
    • Insertion Loss (IL): Measures the optical power attenuation when an optical signal passes through the patch cord connector, measured in \text{dB} . The standard for single-mode fiber optic patch cords typically requires \text{IL} \le 0.3\text{ dB} .
    • Return Loss (RL): Measures the ratio of reflected optical power to incident optical power at the end face, measured in \text{dB} . For example, APC (Angled Physical Contact) polished end faces typically require \text{RL} \ge 60\text{ dB} , while PC (Physical Contact) end faces usually require \text{RL} \ge 50\text{ dB} .
    • Geometric and Physical Structure Parameters: Core/cladding diameter (e.g., single-mode core 9\ \mu\text{m} , cladding 125\ \mu\text{m} ), patch cord length, outer diameter specifications, and applicable operating temperature range.
    • Sensor-Specific Parameters (e.g., including FBG measurement points): If the patch cord integrates Fiber Bragg Gratings (FBGs), the test report will also detail the initial reflection center wavelength \lambda_0 , reflectivity, 3dB bandwidth, and factory calibration formula coefficients for temperature/strain (such as binomial or linear fitting parameters).
II. Official OFSCN® Fiber Optic Patch Cord Product and Specification Examples
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN® / DCYS) produces a variety of industrial-grade and special-environment fiber optic patch cords. Each batch of products must meet stringent factory optical testing and structural inspection standards:
1. Standard Fiber Optic Patch Cords
  • Specification Features: Composed of fiber optic connectors (FC, ST, LC, SC; PC or APC compatible), PVC jacket, Kevlar(aramid fiber)yarn, and single-mode/multi-mode fiber. Default operating temperature range is -20^\circ\text{C} to 50^\circ\text{C} , with the default fiber type being G.652D.
2. Micro Steel Armored Fiber Optic Patch Cord (2.0mm)
  • Specification Features: Incorporates a 0.6\text{mm} stainless steel seamless conduit and PVC outer jacket, providing extremely high mechanical strength (tensile strength > 1500\text{N} , compressive strength > 150\text{Mpa} ) while ensuring low insertion loss.
3. 300℃ High-Temperature Special Fiber Optic Patch Cord
OFSCN® 300℃ Fiber Optic Patch Cord
  • Specification Features: Consists of high-temperature resistant fiber optic connectors, a 0.9\text{mm} stainless steel seamless conduit, and 300℃ polyimide-coated fiber. The operating temperature range covers -270^\circ\text{C} to 300^\circ\text{C} , enabling highly reliable optical signal transmission in extreme environments.
For more information on fiber optic patch cord products with different structures and temperature ratings, please refer to the OFSCN® Fiber Optic Patch Cord Product Classification Link.
