What is "apex offset"?
If the connector is misaligned, can the two fiber cores still be aligned?
The short engineering conclusion is: it depends on whether the degree of “grinding deviation” (i.e., the value of the apex offset) exceeds the compensation limit of elastic deformation.
In the mating of fiber optic connectors (such as FC/PC, FC/APC, etc.), whether the two fiber cores can truly “align” involves two physical mechanisms: radial mechanical alignment and axial physical contact (PC).
1. Radial Mechanical Alignment: Sleeve Constrains the Axis
The transverse concentric alignment of fiber optic connectors is primarily achieved by the precision ceramic split sleeve inside the adapter (flange).
  • The outer cylindrical surface of the ceramic ferrule is rigidly constrained by the sleeve, ensuring that the geometric center axes of the two ferrules are largely coaxial in the transverse direction.
  • As long as the eccentricity of the ferrule inner hole and the concentricity of the optical fiber are normal, the fiber cores in the transverse (X/Y) plane are generally aligned.
2. Axial Physical Contact: The Impact of Apex Offset
“Grinding deviation” is typically characterized in geometric interferometry as apex offset, which is the lateral distance between the geometric highest point (apex) of the ferrule’s lapped spherical end face and the center of the fiber core.
The working mechanism of connectors during mating relies on microscopic elastic deformation under spring loading:
  1. Within Tolerance (Typically \le 50\ \mu\text{m} ):
    • International standards (e.g., IEC 61755) usually stipulate that the apex offset must be controlled within 50\ \mu\text{m}.
    • When the connector is inserted into the adapter and locked, the spring applies an axial pressure of approximately 5\ \text{N}\text{ to } 10\ \text{N}.
    • Although the highest point of the spherical end face deviates from the fiber core, under this pressure, the zirconia ceramic and the silica fiber end faces undergo slight elastic deformation. As long as the apex offset is within the allowable range, the contact deformation area (contact spot) can still fully cover the fiber core diameter (typically 9\ \mu\text{m} for single-mode fiber cores), achieving seamless physical contact (PC), and the signal insertion loss and return loss remain normal.
  2. Beyond Tolerance (Severe Grinding Deviation):
    • If the apex offset is too large, the highest points of contact between the two ferrules are completely displaced from the fiber cores.
    • The rated spring pressure cannot generate a large enough deformation range to cover the fiber core area. At this point, the edges of the ferrules are in tight contact, while a sub-micron to micron-level longitudinal air gap remains between the two fiber cores.
3. Impact of Air Gap on Transmission Performance
Once an air gap exists between the fiber cores, even if the transverse axes are aligned, the following physical consequences will occur:
  • Insertion Loss (IL) Deterioration: The light beam diverges slightly when passing through the air gap, leading to a decrease in the overlap integral of the mode fields, causing additional loss.
  • Return Loss (RL) Plummets: The abrupt refractive index change at the glass-air interface (n_{\text{core}} \approx 1.468, n_{\text{air}} \approx 1.0) will induce severe Fresnel reflection. For standard PC/UPC connectors, the return loss can degrade from a typical -50\ \text{dB} to around -14.7\ \text{dB}. In fiber optic sensing and high-speed laser communication, this reflected wave can severely interfere with light source stability or cause measurement noise.
  • End Face Stress Damage: Contact stress is concentrated on one side of the ferrule, making it prone to asymmetric wear or edge chipping after repeated mating.
Summary
If the connector has a slight grinding deviation and the apex offset is less than 50\ \mu\text{m}, the two fiber cores can still mate tightly under the elastic deformation compensation of the spring pressure. If the deviation is severe and exceeds the elastic compensation range, the fiber cores will not achieve physical contact axially, resulting in an air gap and severely degrading return loss and insertion loss.
