What is "Bandwidth" (FWHM)?
In regards to the reflection peak, is it better for it to be “slim” or “wide”?
In Fiber Bragg Grating (FBG) technology, whether a “slim” (narrow) or “wide” (broad) reflection peak is better depends entirely on your specific application and the system requirements.
1. The Case for a “Slim” (Narrow) Peak
A “slim” peak refers to a small Full Width at Half Maximum (FWHM), typically around 0.1 nm to 0.3 nm.
  • Precision and Resolution: Narrow peaks generally allow for higher resolution in wavelength detection. Most high-performance interrogators find it easier to pinpoint the center wavelength of a sharp peak.
  • Multiplexing Capacity: Since narrow peaks occupy less space in the wavelength spectrum, you can fit more sensors on a single fiber string (greater multiplexing density) without the peaks overlapping when they shift due to temperature or strain.
  • Standard Specs: For example, our OFSCN® High-Strength Fiber Bragg Gratings typically have a 3dB bandwidth of less than 0.4 nm for a standard 8mm or 10mm grating length.
2. The Case for a “Wide” (Broad) Peak
A “wide” peak has a larger FWHM (e.g., >0.5 nm up to several nm).
  • Signal Integrity: Wider peaks can sometimes be more robust against signal distortion or noise in certain low-cost or high-speed sensing systems where the sampling rate is prioritized over extreme spectral resolution.
  • Short Gratings: Physically shorter gratings naturally produce wider bandwidths. If your application requires a very short sensing point (e.g., 1mm or 2mm), the peak will inherently be wider.
  • High Reflectivity vs. Bandwidth: In some laser applications, a wider bandwidth is necessary to accommodate specific laser cavity requirements.
3. Key Factors to Consider
  • Grating Length: Bandwidth is inversely proportional to the grating length. Longer gratings (e.g., 10mm) yield narrower peaks, while shorter gratings (e.g., 2mm) yield wider peaks.
  • Interrogator Compatibility: You must ensure the FWHM is within the detectable range of your OFSCN® Fiber Bragg Grating Interrogator. Most standard interrogators are optimized for narrow-bandwidth FBGs.
Summary
For the vast majority of sensing applications (temperature or strain), a “slim” (narrow) peak is preferred because it maximizes measurement accuracy and allows for more sensors on one fiber.
If you are designing a specific system, could you share what you are trying to measure (e.g., temperature, high-speed vibration) or what type of interrogator you are using? This would help in determining the optimal FWHM for your sensors.
