What is chromatic dispersion in a fiber optic patch cord?
Does dispersion affect the signal speed in ultra-long jumpers (e.g., 1 km)?
In fiber optics, the question of whether dispersion affects signal speed needs to be strictly analyzed from two physical dimensions: the group velocity (time delay) of light propagation and the pulse broadening caused by dispersion (limiting transmission rate).
1. Physical Essence: Light Propagation Speed and Time Delay
The propagation speed of light in single-mode fiber is determined by the group refractive index (N_g) of the fiber core material. Its group velocity (v_g) is:
v_g = \frac{c}{N_g}
  • For standard communication single-mode silica fiber (e.g., G.652D fiber), at the 1550\ \text{nm} wavelength band, N_g \approx 1.468.
  • The absolute propagation speed of the optical signal is approximately v_g \approx 2.04 \times 10^8\ \text{m/s}.
  • For a 1 kilometer (1 km) fiber jumper, the fundamental propagation delay of the optical signal is fixed at:
\tau = \frac{L}{v_g} \approx \frac{1000\ \text{m}}{2.04 \times 10^8\ \text{m/s}} \approx 4.9\ \mu\text{s}
Dispersion does not significantly alter the overall average flight speed of the signal (which remains approximately fixed at \approx 5\ \mu\text{s/km}).
2. Impact of Dispersion on Signal Quality and Maximum Usable Rate
Chromatic Dispersion (CD) refers to the phenomenon where light components of different wavelengths (frequencies) within an optical signal propagate at slightly different group velocities in a medium, causing the optical pulse to broaden in the time domain.
The formula for pulse broadening (\Delta t) caused by dispersion is:
\Delta t = D \times \Delta \lambda \times L
Where:
  • D: The dispersion coefficient of the fiber, in units of \text{ps}/(\text{nm}\cdot\text{km}).
  • \Delta \lambda: The spectral width of the light source, in units of \text{nm}.
  • L: The length of the fiber, in units of \text{km}.
Quantitative Calculation (Example with 1 km of Single-Mode Fiber):
  1. At the 1310\ \text{nm} Zero Dispersion Wavelength:
    • The dispersion coefficient (D) for standard single-mode fiber is approximately D \approx 0\ \text{ps}/(\text{nm}\cdot\text{km}), resulting in virtually zero dispersion broadening.
  2. At the 1550\ \text{nm} Communication and Sensing Window:
    • The dispersion coefficient (D) for standard single-mode fiber (e.g., G.652D) is approximately D \approx 17\ \text{ps}/(\text{nm}\cdot\text{km}).
    • If a narrow linewidth laser (e.g., DFB laser with spectral width \Delta \lambda \approx 0.1\ \text{nm}) is used:
      \Delta t = 17\ \text{ps}/(\text{nm}\cdot\text{km}) \times 0.1\ \text{nm} \times 1\ \text{km} = 1.7\ \text{ps}
      A time broadening of 1.7\ \text{ps} is negligible for most communication rates (including 10 Gbps, where the pulse width per bit is 100\ \text{ps}) and conventional sensing demodulation.
    • If a broad spectrum light source (e.g., LED or SLD superluminescent diode with spectral width \Delta \lambda \approx 40\ \text{nm}) is used:
      \Delta t = 17 \times 40 \times 1 \approx 680\ \text{ps}
      In high-speed intensity modulation, excessive pulse broadening can cause Inter-Symbol Interference (ISI), thereby limiting the maximum modulation frequency/transmission rate of the signal.
3. Conclusions in Engineering and Sensing Applications
  • For Optical Communication Systems: At a distance of 1 km, with conventional semiconductor lasers, the impact of dispersion on signal speed is minimal. The primary system constraints are typically connector insertion loss and fiber attenuation.
  • For FBG Fiber Grating Sensing and Demodulation: The dispersion introduced by a 1 km jumper does not cause wavelength measurement drift. However, in ultra-high-speed transient wavelength sweeping (e.g., with MHz sweep rate lasers) or high-precision Optical Frequency Domain Reflectometry (OFDR), algorithmic compensation for the group delay dispersion of the fiber link might be necessary for baseline calibration.
