How long will fiber materials last on a machine that is constantly vibrating?
On continuously vibrating machinery, the physical lifespan of a silica (SiO_2) based fiber material depends on dynamic fatigue mechanisms, alternating stress (strain) amplitude, and the fiber’s coating and protective packaging structure.
I. Physical Mechanism of Fiber “Dynamic Fatigue”
Quartz fibers theoretically possess extremely high fracture strength (up to 5\,\text{GPa}), but in practical production and use, microscopic nano-scale cracks inevitably exist on the fiber surface and cladding. The fatigue failure of optical fibers is mainly controlled by the Stress Corrosion Mechanism (Subcritical Crack Growth):
- Synergistic Action of Chemical Reaction and Stress: When the fiber undergoes continuous vibration with machinery, the tips of micro-cracks bear dynamic tensile stress. Water molecules (H_2O) in the environment react with siloxane bonds under tensile stress through hydrolysis:
Si-O-Si + H_2O \rightarrow 2 Si-OH - Crack Propagation and Fracture: The hydrolysis reaction leads to the chemical bond breaking of micro-cracks and slow internal propagation. Over time, the crack depth reaches a critical size, causing brittle fracture of the fiber.
- Dynamic Fatigue Parameter (n_d): International standards (e.g., IEC 60793-1-33) define the dynamic fatigue parameter n_d for optical fibers. Ordinary acrylate-coated fibers typically have n_d values between 20 \sim 25. A higher n_d value indicates a stronger resistance of the material to dynamic fatigue crack growth.
According to the power-law model of fiber crack growth, the fiber fracture lifetime t_f is inversely proportional to the dynamic alternating stress amplitude \sigma exponentially:
t_f \propto \sigma^{-n_d}
II. How Long Can Fiber Materials Last on Vibrating Equipment?
The actual service life of optical fibers in vibrating environments can range from a few days to over 20 years, specifically determined by the following key parameters:
1. Dynamic Strain (Stress) Amplitude
- Safe Strain Range (Lifespan > 20 years): If the dynamic bending and tensile micro-strain amplitude caused by machine vibration is consistently kept within 20\% \sim 30\% of the fiber’s ultimate strength (typically corresponding to dynamic tensile strain < 1000 \sim 2000\,\mu\varepsilon), the crack growth rate of the fiber is extremely slow, and the theoretical fatigue life can exceed 20 years.
- High Stress Fatigue Range (Significantly Reduced Lifespan): If strong equipment vibration causes local stress concentration or the dynamic strain persistently exceeds 5000\,\mu\varepsilon, the crack growth rate will accelerate exponentially, and the fiber may undergo fatigue fracture within days or weeks.
2. Coating Material and Stripping Damage
- Ordinary UV-cured acrylate coatings are prone to micro-delamination and aging under long-term high-frequency vibration and friction, failing to continuously block moisture.
- Fibers using Polyimide coating materials have extremely high adhesion to the quartz glass cladding, more effectively slowing down moisture permeation and micro-crack growth.
- If the coating is stripped and reapplied when writing devices like Fiber Bragg Gratings (FBGs), micro-defects at the re-coating interface will significantly reduce the dynamic fatigue life. Conversely, technologies like femtosecond laser point-by-point writing that do not damage the coating greatly preserve the fiber’s inherent high tensile strength and fatigue resistance.
3. Mechanical Encapsulation and Bend Radius Control
When bare fibers are directly fastened to vibrating equipment, shear forces at structural edges and sharp bends (bend radius less than the critical radius, e.g., r < 15\,\text{mm}) can cause local stress concentration. Industrial applications typically employ flexible alloy tubes or polymer protective sheaths to protect the fiber, limit mechanical bending limits, and dissipate alternating stresses.
III. Official Technical and Product Correlation (OFSCN® Solutions)
For monitoring scenarios requiring long-term operation in environments with strong vibration and high-frequency alternating stresses, Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) offers the following high-fatigue resistance fiber and sensor products:
High-Strength Femtosecond Fiber Bragg Gratings (Bare Grating)
Utilizing femtosecond laser point-by-point writing technology, directly writing into the fiber core through the coating without stripping and re-coating, maintaining the fiber’s inherent high tensile strength. It can withstand dynamic stress up to \ge 25000\,\mu\varepsilon:
OFSCN® High-Strength Fiber Bragg Gratings / FBG Strings (Bare)
Polyimide-Coated Fiber Bragg Gratings
Employing high-adhesion polyimide coating, possessing excellent mechanical fatigue resistance and temperature characteristics, with a strain tolerance up to \le 10000\,\mu\varepsilon:
OFSCN® Polyimide Fiber Bragg Gratings / FBG Strings (Bare)
Alloy Tube Packaged Fiber Bragg Grating Strain Sensor
Utilizing seamless flexible alloy tubes to isolate external shear forces and high-frequency abrasion, effectively dissipating vibration alternating stresses and ensuring long-term service life on industrial vibrating equipment:
