If the fiber is installed on a vibrating engine, would this back-and-forth movement shorten its lifespan?
tool_0:
Yes, continuous vibrations and back-and-forth movements generated by equipment like engines significantly shorten the lifespan of bare optical fibers. This phenomenon is known in fiber optics physics and material reliability engineering as Dynamic Fatigue.
I. Physical Principles: What is “Dynamic Fatigue” in Optical Fibers?
While silica (\text{SiO}_2) quartz fibers possess extremely high tensile strength, their surfaces inevitably contain microscopic defects and microcracks.
When a fiber is installed on a vibrating engine, the swaying induces alternating tensile stress (\sigma) and bending stress in the fiber. Under the combined influence of dynamic stress and environmental moisture (\text{H}_2\text{O}), the fiber undergoes Stress Corrosion:
- Chemical Bond Rupture: Under stress concentration, water molecules attack and break the \text{Si-O-Si} siloxane bonds at the crack tips.
- Crack Propagation: Due to the alternating stress (dynamic loading) from vibrations, cracks gradually expand from microscopic sizes until they reach the critical fracture dimension, ultimately leading to fiber breakage.
- Dynamic Fatigue Parameter n_d: In materials science, the dynamic fatigue stress corrosion exponent n_d (Dynamic Fatigue Parameter) is commonly used to assess a fiber’s resistance to dynamic stress-induced failure. The crack propagation rate is closely related to the applied dynamic strain rate.
Therefore, the greater the engine vibration amplitude, the higher the frequency, and the smaller the installation bend radius, the more pronounced the dynamic stress concentration within the fiber becomes, and the faster its fatigue life degrades.
II. Key Factors Affecting Fiber Lifespan in Engine Vibration Environments
- Alternating Strain Amplitude (\varepsilon): A smaller dynamic bending radius (R) induced by vibration leads to greater tensile stress on the outer core of the fiber, accelerating fatigue failure.
- Ambient Temperature and Humidity: Engine compartments are typically associated with high temperatures and humidity. Elevated temperatures accelerate the chemical reaction process of stress corrosion.
- Coating and Structural Protection: The acrylate coating on ordinary optical fibers tends to age and peel off in high-temperature, vibrating environments, losing its protective function for microcracks.
III. Protective Measures and Product Solutions in Industrial Engineering
To prevent dynamic fatigue failure caused by engine vibrations, bare optical fibers are generally not used directly. Instead, techniques such as seamless steel pipe armoring or metal/alloy tube encapsulation are employed to isolate external mechanical vibrations and enhance temperature resistance.
In Beijing Dacheng Yongsheng Technology Co., Ltd.'s (OFSCN®) product line, the following standardized structures and sensors are offered for high-vibration, dynamic stress, and high-temperature environments:
1. Vibration and Dynamic Stress Measurement
For dynamic stress/strain monitoring on vibrating structural components like engines, alloy tube encapsulation significantly dampens alternating stress concentration and protects the fiber core:
2. High-Temperature, Vibration-Resistant Armored Fiber Optic Cable
For signal transmission or distributed sensing, seamless stainless steel pipe (FIMT) encapsulation completely isolates external alternating physical wear and provides moisture protection:
3. High-Temperature, High-Adhesion Specialty Optical Fiber
At the fiber level, polyimide (PI) coatings offer higher temperature resistance and a tighter bond with the quartz cladding compared to traditional coatings, effectively slowing down dynamic fatigue propagation:
