What is vibration resistance?
In places with severe engine vibration, will the encapsulated structure be shaken apart?
In extreme operating conditions with high-frequency, large-amplitude vibrations (strong vibrations) in engines, turbines, etc., traditional sensor packaging structures indeed carry a significant risk of being “shaken apart” or suffering physical damage. However, for these harsh conditions, integrated fiber optic sensors exhibit excellent vibration resistance in terms of both physical structure and material processing.
Below, we will analyze from two dimensions – physical mechanisms and packaging engineering design – why traditional structures are prone to being shaken apart and how to prevent it:
I. The Risk of “Disintegration” for Traditional Sensors in Strong Vibration Environments
  1. Loosening of Threaded Connections and Failure of Splice Interfaces
    Traditional multi-component sensors relying on threaded or screw-based splicing are highly susceptible to microscopic friction under continuous high-frequency alternating stress, leading to self-loosening failure (i.e., thread loosening). Over time, the packaging structure will gradually loosen and fall apart.
  2. Fatigue Cracking of Adhesives under Thermal-Vibration Coupling
    Engine compartments typically experience high temperatures (e.g., 100\ ^\circ\text{C} to 300\ ^\circ\text{C}). Many conventional sensors use polymer adhesives like epoxy resin for encapsulation. These materials undergo thermal aging and become brittle at high temperatures. Under the alternating stress of strong vibrations, fatigue cracks are easily generated, ultimately leading to the delamination of internal components from the protective casing and disintegration.
  3. Metal Fatigue of Electrical Leads
    Traditional electrical sensors (such as thermocouples and resistance strain gauges) have relatively heavy metal leads and solder joints. Under intense vibration, these components, due to their relatively large mass, experience significant inertial forces. Metal fatigue and eventual fracture are likely to occur at the bends of the solder joints.
II. The Intrinsic Physical Advantages of FBG (Fiber Bragg Grating) Sensors Against Vibration
Compared to traditional electrical sensors, Fiber Bragg Grating (FBG) sensors possess superior inherent anti-vibration characteristics:
  • Extremely Small Mass and Inertial Force: The outer diameter of the fiber’s quartz glass core and cladding is typically only 125\ \mu\text{m}. Due to its minimal mass, even under strong vibrations with extremely high acceleration (high g-values), the inertial force experienced by the fiber itself is negligible, and it is unlikely to fracture or detach due to vibration-induced fatigue.
III. How OFSCN® Addresses Vibration Resistance in Engine Environments
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) has implemented targeted optimizations in structural design and manufacturing processes to address extreme industrial environments characterized by high vibration and alternating high/low temperatures, thereby eliminating the safety hazard of “disintegration”:
1. Integrated Seamless Metal Tube Packaging Eliminates Mechanical Splices
OFSCN® sensors abandon traditional multi-section splicing and threaded fixation structures. Their core protective sheath utilizes integrated packaging with continuous, seamless metal tubes (such as 304/316L stainless steel or high-strength alloy tubes). With no splice interfaces or threaded connections, the sensor’s physical structure fundamentally lacks assembled parts that could be “shaken apart.”
  • OFSCN® 300°C Fiber Bragg Grating Temperature Sensor: Employs a monolithic seamless steel tube integration technology with a standard outer diameter of 0.9\ \text{mm} (customizable to a minimum outer diameter of 0.5\ \text{mm}). Its structure is cohesive and can directly withstand high-frequency, high-intensity physical jolts.
  • OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor: Utilizes an alloy tube packaging process that securely locks the Fiber Bragg Grating or grating array inside the metal tube. The standard outer diameter is \le 1.1\ \text{mm}, specifically designed for mechanical and vibration measurements in harsh industrial environments.
2. Inorganic Sealing and Tight-Pack Technology Prevent Internal Friction
To prevent the internal fiber from repeatedly colliding and frictioning with the metal wall within the seamless steel tube due to vibration, OFSCN® employs unique inorganic potting and high-temperature metallization bonding or tight-pack processes. This integrates the fiber with the metal sheath. There are no loose internal components, ensuring not only extremely high heat/force transfer efficiency but also absolute stability of the internal structure under long-term high-frequency alternating stress.
3. Fully Passive System Eliminates Risks of Broken Wires and Desoldering
Fiber optic sensors lack complex circuit boards, surface-mount components, and electronic solder joints. Signal transmission relies on fused, integrated optical fibers. Connection points can be protected with stainless steel armored patch cords. This minimalist, reliable physical architecture offers exceptionally long fatigue life in harsh thermal-vibration coupling environments like engine compartments.
Conclusion
In areas with intense vibrations like engines, ordinary assembled or adhesive-bonded sensors are indeed at risk of disintegration and failure. However, by choosing OFSCN® Fiber Bragg Grating sensors featuring integrated seamless steel/alloy tube packaging, no threaded mechanical splices, and employing tight-pack or inorganic potting techniques, their physical structure makes them impossible to be “shaken apart,” enabling long-term stable operation.
