What is "end-face flatness"?
Why must fiber optic end faces be flat? What happens if they are angled or have burrs?
In fiber optics and fiber engineering, the verticality (Cleave Angle) and surface flatness & smoothness of a fiber end-face are critical physical metrics that determine optical transmission efficiency, splicing quality, and system stability.
Taking common communication-grade and sensing-grade single-mode quartz fibers (e.g., with a core diameter of approximately 9\ \mu\text{m} and a cladding diameter of 125\ \mu\text{m}) as an example, if the fiber end-face exhibits tilt (excessive cutting angle) or microscopic defects (burrs, cracks, nicks, lips), it can lead to a series of physical and engineering problems:
I. Why Must Fiber End-faces Be Flat and Perpendicular?
  1. Meeting Waveguide Coupling and Mode Field Matching
    The Mode Field Diameter (MFD) of single-mode fiber is only about 9\sim 10\ \mu\text{m}. Light propagates axially within the core in the fundamental mode (\text{LP}_{01}). When light is incident from one fiber to another, only when both end-faces are strictly parallel, tightly abutted, and perpendicular to the fiber axis can the overlap integral of the waveguide modes be maximized, achieving extremely low-loss optical energy transmission.
  2. Surface Tension Balance During Splicing
    During Fusion Splicing, silica (\text{SiO}_2) glass softens and melts under the high temperature of the electric arc. Flat and perpendicular end-faces allow the surface tension acting on the molten glass from both sides to be symmetrically distributed, enabling self-alignment and uniform, dense molecular reconstruction.
II. What Happens If the End-face Is Tilted or Has Burrs?
1. In Fusion Splicing Scenarios
  • Drastic Increase in Splice Loss:
    If the cleave angle is too large (typically, standard splicing machines require a cleave angle \theta < 1.0^\circ for single-mode fiber, with high-precision splicing requiring \theta < 0.5^\circ), the molten region during arc discharge will cause the core to tilt or axially misalign, leading to severe mode field mismatch loss.
  • Formation of Air Bubbles and Voids:
    When the end-face has burrs or nicks, irregular edges during discharge can cause localized discharge anomalies or entrap air, forming microscopic bubbles or unfused defects within the splice, leading to intense scattering loss.
  • Direct Error Reporting and Rejection by Splicing Machine:
    Modern fiber splicers use machine vision systems to pre-evaluate the cleaved end-faces. If the end-face tilt angle is out of tolerance, or if there is unevenness or edge burrs, the machine will directly report “Poor End-face” and interrupt the splicing process.
  • Significant Degradation of Mechanical Strength and Tensile Performance:
    After splicing, an end-face with burrs or cracks is prone to residual micro-cracks and stress concentration points, making it susceptible to brittle fracture under tensile load, bending, or thermal cycling.
2. In Butt Coupling / Connector Scenarios
  • Disruption of Physical Contact (PC) and Exacerbation of Fresnel Reflection:
    Fiber optic connectors rely on precise end-face grinding and elastic deformation for tight contact. If the end-face is tilted or has protruding burrs, the two fibers cannot achieve conformal physical contact, and an air gap will form between the end-faces. The refractive index discontinuity between air (refractive index n_0 \approx 1.0) and the fiber core (refractive index n_1 \approx 1.45) will cause strong Fresnel reflection, significantly worsening Return Loss and potentially interfering with the normal operation of light sources (such as lasers).
  • Beam Refraction and Angular Deviation:
    According to Snell’s Law, a slanted end-face will cause the outgoing light beam to deflect, preventing accurate coupling along the optical axis into subsequent optical components.
3. In High-Power Laser and Sensing Scenarios
  • Localized Photothermal Damage (Fiber Fuse):
    Burrs, surface roughness defects, or dust adhesion points significantly increase light scattering and absorption. Under high optical power density injection, the defects absorb energy, heat up intensely, and can easily induce end-face burning or the “fiber fuse effect.”
III. Engineering Evaluation Standards
In the preparation and inspection of fiber end-faces, fiber end-face testers (Interferometer / Video Microscope) are typically used for quantitative evaluation from the following dimensions:
Parameter Standard for High-Quality End-face (Telecom/Sensing Grade) Poor End-face Characteristics Typical Consequences
Cleave Angle Typically < 1.0^\circ (High precision < 0.5^\circ ) Tilt Angle > 2^\circ \sim 3^\circ Axial alignment deviation, increased splice loss
Surface Roughness and Flatness Mirror-like flatness (No defects in the mirror zone) Presence of Mist or Hackle zones Increased light scattering, enlarged connection gap
Edge Integrity Smooth and intact edge, no nicks Lips, burrs, nicks Bubble formation, sharp decrease in splice strength
(Note: Fiber cleavers, grinding discs, and end-face microscopes are common tools for fiber construction and laboratory processing and are not part of Beijing Dacheng Yongsheng Technology Co., Ltd.'s OFSCN® core product line.)
