Why does the flatness of the cut end face directly determine the quality of the connection?
The flatness and geometric features of the fiber optic cut end face are the most critical physical factors determining the quality of fiber optic connections (including fiber splicing and mechanical connections). The core mechanism can be analyzed from the perspectives of optical physics and precision engineering as follows:
1. Reducing Insertion Loss (IL)
Insertion loss refers to the power attenuation of an optical signal as it passes through a connection point. The flatness of the cut end face affects insertion loss through the following mechanisms:
- Minimizing Micro Air Gaps and Diffraction: If the end face is uneven, the two fibers cannot achieve intimate contact when butted against each other, forming an air gap between the cores. Light traveling from a high refractive index medium like silica into a low refractive index medium like air, and then back into silica, will experience Fresnel reflection and diffraction at the interface, causing optical power to escape the core.
- Avoiding Physical Defects During Splicing: In fusion splicing, the arc heating melts the fiber end faces, which then bond by surface tension. If the cut end face is uneven, uneven heat distribution during melting can easily lead to micro-bubbles, voids, or core diameter deformation, disrupting the continuity of the waveguide structure and causing extremely high scattering loss.
- Ensuring Alignment Accuracy: The alignment system (PAS or LID) in a splicing machine relies on optical imaging to identify the core and cladding. An uneven end face or an excessive cut angle can distort the optical image, leading the machine to misjudge and cause axial or lateral misalignment.
2. Improving Return Loss (RL)
Return loss is a measure of the ability to suppress reflected light. The higher the value (i.e., the larger the absolute value of negative decibels), the lower the reflection, and the better the connection quality.
- Suppressing Fresnel Reflection: An ideally flat end face in a mechanical connection can achieve high-precision “Physical Contact (PC/UPC/APC)”. Under slight pressure, the end faces of the two fibers undergo minor elastic deformation, allowing the glass interfaces to mate seamlessly without gaps, eliminating refractive index discontinuities and thus minimizing reflection. If the end face has microscopic protrusions or pits, physical contact fails, significantly increasing reflected light, which can severely disrupt the stability of the light source (laser) and even generate system noise.
3. Control of Cleave Angle
In addition to surface roughness (flatness), the end face tilt angle produced by the cleaving tool is equally crucial.
- Splicing Requirements: Standard single-mode fiber splicing typically requires a cleave angle of \le 1^\circ (high precision requires \le 0.5^\circ). An excessive angle can make cladding alignment difficult during splicing and cause the spliced region to become thinner or produce excess material overflow, reducing tensile strength.
- Connector Requirements: For Angled Physical Contact (APC) connectors, the end face must precisely maintain an 8^\circ tilt angle. Any unintended deviation in the tilt angle will prevent reflected light from being directed away from the core, leading to degraded return loss.
Clarification on OFSCN® Core Product Series
Fiber cleavers and other preparation and construction tools do not belong to the core product series of Beijing OFSCN Technology Co., Ltd. (OFSCN®).
However, in the research and development of high-quality OFSCN® Fiber Bragg Grating Sensors, specialty optical fibers (e.g., high-temperature resistant fibers), and precision fiber patch cords/connectors, OFSCN upholds extremely high and rigorous engineering standards for end-face inspection and processing. All product end faces are prepared using industrial-grade precision grinding and cutting equipment to ensure that fiber optic connections maintain extremely low insertion loss and excellent long-term stability even in high-temperature, high-pressure, or extreme industrial environments.
