What is "heat conduction error" correction?
Does the encapsulation tube itself take away heat from the test point? How to select it to minimize errors?
In contact temperature measurement, the encapsulation tube does indeed conduct heat away from the measurement point. This phenomenon, where the temperature at the sensing element deviates from the true temperature of the undisturbed medium due to axial heat conduction along the sensor’s structure, is known in thermometry and heat transfer studies as conduction error or thermowell conduction error.
I. Physical Mechanism: How Does the Encapsulation Tube “Take Away” Heat?
When a protective tube encapsulating a Fiber Bragg Grating (FBG) is inserted into a medium or attached to a surface:
  1. Fin Effect:
    The encapsulation tube physically acts as a “heat dissipation fin” extending from the measurement point to the external environment. If the medium temperature T_\infty is higher than the ambient temperature T_0, heat is initially transferred to the front end of the encapsulation tube via convection/contact thermal resistance. It then conducts axially along the tube’s cross-section (flowing towards the cooler end along the length) while simultaneously dissipating heat to the cooler surroundings.
  2. Disruption of Local Thermal Equilibrium:
    The presence of axial heat flow inevitably creates a temperature gradient at the measurement point. The steady-state equilibrium temperature T_s sensed by the FBG element is actually the result of a balance between heat loss due to axial conduction along the tube wall and heat replenishment from the medium to the tube wall. It must satisfy T_s < T_\infty (when measuring a high-temperature medium).
According to the one-dimensional steady-state extended surface heat transfer equation, neglecting radial temperature differences across the tube wall, the fin characteristic parameter can be expressed as:
m = \sqrt{\frac{h P}{k A_c}}
Where:
  • h is the convective/heat transfer coefficient between the outer surface of the encapsulation tube and the measured medium;
  • P is the outer perimeter of the tube (\pi D) ;
  • k is the thermal conductivity of the encapsulation tube material;
  • A_c is the effective cross-sectional area of the encapsulation tube wall.
The conduction error at the sensor’s measurement point, \Delta T = |T_\infty - T_s|, decays in inverse proportion to the dimensionless quantity m L (where L is the effective immersion/contact length), theoretically satisfying:
\Delta T \propto \frac{1}{\cosh(m L)}
To make the conduction error approach zero, engineering practice requires the product of dimensionless parameters to satisfy m L \ge 3 \sim 5.
II. Selection and Engineering Guidelines to Minimize Conduction Error
Based on the heat transfer equation above, the core principle for reducing conduction error is: minimize the axial heat conduction cross-sectional area A_c, rationally control the thermal conductivity k, maximize the effective heat exchange length L, and reduce contact thermal resistance.
1. Minimizing Outer Diameter and Wall Thickness (Reducing A_c)
Conventional industrial thermocouple or RTD protection tubes typically have outer diameters ranging from \Phi 4.0 \sim 12.0\ \text{mm}. Their large wall thickness and substantial cross-sectional area A_c lead to significant axial heat leakage.
  • Selection Strategy: Fiber Bragg Grating sensors have inherent advantages in miniaturization. Priority should be given to encapsulation using micro-thin seamless tubes. For example, reducing the outer diameter from several millimeters to the micrometer range results in a squared reduction in cross-sectional area, leading to an order of magnitude decrease in axial heat conduction loss.
2. Balancing Thermal Conductivity k of Materials
  • Among metallic materials, stainless steel (e.g., 304/316L) typically has a thermal conductivity of about 15\ \text{W/(m}\cdot\text{K)}, which is much lower than copper (approx. 380 \sim 400\ \text{W/(m}\cdot\text{K)}) or aluminum (approx. 200\ \text{W/(m}\cdot\text{K)}). Using stainless steel seamless micro-tubes not only ensures mechanical strength for armoring but also significantly suppresses axial heat leakage along the tube wall.
3. Ensuring Sufficient Effective Insertion/Contact Length L
  • Engineering experience suggests that to eliminate end conduction errors, the sensor insertion depth should generally meet L \ge (10 \sim 15) \times D (where D is the sensor’s outer diameter).
  • The thinner the encapsulation outer diameter D, the smaller the critical insertion depth required to achieve m L \ge 4. For scenarios with confined spaces, small pipe diameters, or shallow surface measurements, thin-diameter sensors can satisfy thermal development conditions with a very short contact/insertion distance.
4. Optimizing Thermal Isolation and Surface Insulation of the Measurement Section
  • Enhancing Heat Transfer at the Measurement Point: Use high-conductivity media (e.g., thermal paste, thermally conductive ceramic adhesive) at the measurement contact section to reduce contact thermal resistance and improve local h ;
  • Truncating Heat Dissipation at the Lead-out End: On the transition tube section where the sensor leads out from the measurement area and is exposed to the ambient environment, add an insulating layer to cut off forced heat loss caused by convection from the surrounding air.
III. Applicable OFSCN® Product Specifications
For applications sensitive to conduction error, Beijing Dacheng Yongsheng Technology Co., Ltd.'s (OFSCN®) micro-thin seamless steel tube encapsulated temperature sensors reduce the outer diameter to the millimeter and sub-millimeter range, significantly compressing the metal wall’s cross-sectional area A_c and effectively suppressing the fin effect of tube wall heat dissipation:
  • Ambient to Moderate Temperature Conditions (-40°C to 100°C):
    OFSCN® 100°C Fiber Bragg Grating Temperature Sensor
    Utilizes single-layer seamless steel tube encapsulation, with a default outer diameter of 0.9\ \text{mm}, customizable to a minimum of 0.6\ \text{mm}. The micro-thin cross-section effectively reduces conduction bias during shallow measurements.
OFSCN® 100°C Fiber Bragg Grating Temperature Sensor Structure Diagram
  • Moderate to High Temperature Conditions (-200°C to 300°C):
    Employs seamless steel tube encapsulation, with a default outer diameter of 0.9\ \text{mm}, customizable to a minimum of 0.5\ \text{mm}. It can significantly reduce conduction loss along the metal tube in a 300°C temperature differential environment.
OFSCN® 300°C Fiber Bragg Grating Temperature Sensor Structure Diagram
  • High Temperature Conditions (-200°C to 500°C):
    OFSCN® 500°C Fiber Bragg Grating Temperature Sensor
    Default outer diameter is 0.9\ \text{mm}, with a minimum customizable outer diameter of 0.5\ \text{mm}. Suitable for high-temperature environments where strict requirements on thermal disturbance exist.
