What is heat conduction error?
Does a metal-armored jumper transfer external heat into the equipment?
Yes, metallic armored fiber optic patch cords do conduct heat from the external environment to the inside of the equipment.
In optical engineering and thermodynamics, this phenomenon is known as “Heat Leak” caused by a “Thermal Bridge”, which is one of the main reasons for “Heat Conduction Error” or temperature fluctuations of sensitive components inside the equipment.
I. Physics Principles and Heat Transfer Mechanism
According to the laws of thermodynamics, as long as there is a temperature difference (\Delta T) between the outside and inside of the equipment, heat will spontaneously transfer from the high-temperature region to the low-temperature region along the medium. The metal protective sheath (such as stainless steel seamless steel pipe or armored hose) in the armored patch cord, as a good conductor, follows Fourier’s Law of Heat Conduction in its heat transfer process:
Q = -k \cdot A \cdot \frac{dT}{dx}
Where:
  • Q is the heat conduction power (i.e., the amount of heat transferred along the channel per unit time);
  • k is the thermal conductivity of the material;
  • A is the cross-sectional area of the heat transfer medium;
  • \frac{dT}{dx} is the temperature gradient along the direction of conduction.
In the structure of fiber optic patch cords, the thermal conductivity (k) of different materials varies greatly:
  • Metallic armor layer (e.g., stainless steel): k \approx 15\ \text{W/(m}\cdot\text{K)}
  • Quartz fiber (silica): k \approx 1.4\ \text{W/(m}\cdot\text{K)}
  • Polymer materials (e.g., coating or jacket): k \approx 0.15 \sim 0.4\ \text{W/(m}\cdot\text{K)}
Since the thermal conductivity of metal is about an order of magnitude higher than that of quartz fiber and two orders of magnitude higher than that of polymer materials, the metallic armor layer constitutes the absolutely dominant heat conduction channel. Even if the wall thickness of the armored pipe is very thin (cross-sectional area A is small), the heat leakage it causes cannot be ignored in precision testing or ultra-high vacuum/cryogenic environments.
II. Related OFSCN® Armored Products
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) produces high-temperature armored patch cords that use an extremely compact 0.9 mm stainless steel seamless steel pipe as the protective layer, minimizing the metal cross-sectional area (A) to reduce the overall heat conduction while providing mechanical protection. Typical products include:
These patch cords use stainless steel pipes to encapsulate the internal polyimide high-temperature resistant fiber. Although their physical size is reduced to 0.9 mm, directly passing this steel pipe through the equipment chamber boundary will still introduce non-negligible heat conduction errors in high-precision temperature measurements and vacuum isolation applications.
III. Engineering Suppression and Protection Strategies
To eliminate or reduce the heat conduction error caused by metallic armor, the following three solutions are generally recommended in engineering applications:
  1. Stripping Armor at the Boundary (Segmented Protection)
    Before the patch cord passes through the equipment or sealed chamber boundary, strip the metallic armor pipe, allowing only the internal bare fiber (such as quartz fiber with a polyimide coating with a diameter of only 125\ \mu\text{m}) to pass through the sealed boundary. Since the cross-sectional area of quartz glass is minimal and its thermal conductivity is low, its heat conduction rate can be ignored.
  2. Thermal Anchoring / Heat Sinking
    Before the armored patch cord enters the sensitive area inside the equipment, securely clamp the metallic armor pipe to the equipment’s outer casing or a dedicated metal heat sink. This allows most of the heat conducted from the outside along the steel pipe to be diverted and dissipated into the environment at the boundary, preventing it from further conducting along the fiber towards sensors or core components deep inside the equipment.
  3. Using Specialized Feedthroughs
    If the equipment requires strict vacuum isolation or airtight protection (such as vacuum chambers, cryogenic dewars), direct passage through steel pipes should be avoided. It is recommended to use specialized sealed feedthrough components, utilizing low thermal conductivity special sealing adhesives or metal welding to seal the fiber optic cable within a flange:
    OFSCN® High-Temperature Fiber Optic Connectors/Flanges/Splitters Category Link
