Why does fiber optic cable undergo “hydrogen loading”? Is it to make it more sensitive to lasers?
Yes, your understanding is spot on! The process of making optical fibers
“absorb hydrogen”—academically and technically known as “Hydrogen Loading”—is primarily aimed at significantly enhancing the fiber core’s “photosensitivity” to lasers (especially specific wavelengths of UV lasers), thereby enabling the high-efficiency, high-quality inscription of Fiber Bragg Gratings (FBGs).
Below is a detailed explanation of the physical and chemical mechanisms behind “Hydrogen Loading” and its critical role in FBG manufacturing.
I. Why is it difficult to directly inscribe gratings in ordinary optical fibers?
Ordinary single-mode optical fibers (e.g., standard \text{G.652D} fiber) have a core typically doped with germanium dioxide ( \text{GeO}_2 ). When exposed to ultraviolet (UV) lasers (such as 244\ \text{nm} or 193\ \text{nm} ), the refractive index of germanium dioxide undergoes small, permanent changes. This physical phenomenon is known as photosensitivity.
However, in its natural state, the photosensitivity of standard optical fibers is very weak. The refractive index modulation ( \Delta n ) caused by light exposure is usually only on the order of 10^{-5} . Such a minute change in refractive index makes it difficult to inscribe high-reflectivity (e.g., $
vert 70% or even
vert 99% $ ) or short-grating-period quality FBGs within the fiber.
II. How does Hydrogen Loading enhance photosensitivity?
To make optical fibers more sensitive to UV lasers, we need to perform “Hydrogen Loading.” The basic process is as follows:
High-Pressure Diffusion:
The optical fiber, with parts of its coating stripped (or using special coatings), is placed in a vessel filled with high-pressure hydrogen gas ( \text{H}_2 , typically at pressures from 10\ \text{MPa} to 20\ \text{MPa} or even higher) and maintained at a specific temperature (e.g., 50^\circ\text{C} to 80^\circ\text{C} ) for several days to weeks. During this process, hydrogen molecules gradually diffuse and saturate the silica core of the optical fiber. -
Photochemical Reaction:
When this “hydrogen-saturated” fiber is exposed to UV laser light (e.g., through a mask), the dissolved \text{H}_2 molecules, under the combined action of photons, undergo vigorous photochemical reactions with germanium-oxygen bonds ( \text{Ge-O} ). These reactions generate stable hydroxyl groups ( \text{Si-OH} and \text{Ge-OH} ) and germanium defect centers with strong absorption characteristics. -
Significant Refractive Index Increase:
These defect centers and chemical bond changes formed by photochemical reactions drastically increase the permanent refractive index change ( \Delta n ) in the illuminated areas to the order of 10^{-3} or even 10^{-2} , an improvement of two orders of magnitude compared to un-loaded fibers. This allows for the easy inscription of high-reflectivity, narrow-bandwidth, high-quality gratings.
III. Post-Loading Procedure: Annealing (Hydrogen Dissipation)
While Hydrogen Loading significantly enhances photosensitivity, it also introduces a side effect: unreacted free \text{H}_2 molecules will slowly escape from the fiber at room temperature, leading to slow wavelength drift of the inscribed grating. Additionally, hydrogen molecules themselves can cause absorption loss around 1.24\ \mu\text{m} and 1.7\ \mu\text{m} .
Therefore, after grating inscription, the optical fiber must undergo annealing (Annealing) in a high-temperature oven. High-temperature heating completely removes unreacted free hydrogen and stabilizes the grating’s microstructure, ensuring long-term wavelength stability during use.
IV. Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) Related Products and Processes
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®), in the production of standard and high-temperature resistant bare Fiber Bragg Gratings and grating strings, employs rigorous hydrogen loading, precision UV inscription, high-temperature annealing (hydrogen dissipation), and professional re-coating processes to ensure high mechanical strength and long-term wavelength stability of the photosensitive sensing units.
Below are core Bare FBG products manufactured using this high-quality hydrogen loading inscription process:
1. OFSCN® Polyacrylate Fiber Bragg Gratings / FBG Strings (Bare)
This product is manufactured using standard \text{G.652D} or \text{G.657} single-mode optical fibers. Prior to inscription, the fiber undergoes rigorous hydrogen loading and de-coating treatment. After inscription and annealing, polyacrylate is applied for high-precision re-coating.
- Operating Temperature Range:** -40^\circ\text{C} to 100^\circ\text{C}
- Maximum Strain Range:** \le 10000\ \mu\varepsilon
2. OFSCN® Polyimide Fiber Bragg Gratings / FBG Strings (Bare)
This product is designed for medium-to-high temperature and wide-temperature range environments. It utilizes standard \text{OFSCN}^\circledR single-mode polyimide fiber. High-pressure hydrogen loading is performed before inscription. After inscription, high-temperature resistant polyimide material is used for re-coating, effectively withstanding harsh environmental temperature fluctuations.
- Operating Temperature Range:** -200^\circ\text{C} to 300^\circ\text{C}
