What is "installation space optimization"?
How to save 50% of space in a narrow cabinet using cable organizers?
In narrow communication and data cabinets, approximately 50\% of space can be saved through the rational layout and selection of a Cable Management System, typically based on comprehensive engineering design that frees up Rack Unit (RU, \text{U}) space and compresses wiring harnesses. The main implementation paths are as follows:
I. Core Engineering Principles and Solutions for Saving 50% Space
1. Adopting “0U Vertical Cable Management” Instead of Traditional “1U Horizontal Cable Management”
  • Traditional Occupancy Mode: In standard cabinet cabling design, a 1:1 configuration rule is usually followed, meaning that for every 1\text{U} Patch Panel installed, a 1\text{U} Horizontal Cable Manager must be placed above or below it. This implies that in purely cabling areas, the cable manager itself occupies 50\% of the rack height (e.g., in a 24\text{U} total cabling space, cable managers take up 12\text{U}).
  • Optimization Strategy: Eliminate all horizontal cable managers that occupy the effective height between the rack vertical posts and use 0U Vertical Cable Organizers installed on the outside of the vertical rails on the cabinet sides, in the gaps between the posts and the side panels.
  • Savings Effect: Directly free up all rack height previously occupied by horizontal cable managers, allowing patch panels to be installed compactly and continuously. This increases the vertical rack space utilization efficiency by 100\%, effectively saving 50\% of the vertical rack space for the same equipment capacity.
2. Using Angled Patch Panels to Eliminate the Need for Horizontal Cable Managers
  • Structural Design: Angled patch panels protrude outwards in a shallow “V” shape. After patch cords are inserted into the ports, they naturally fan out at an angle towards the vertical cable management channels on the left and right sides of the cabinet.
  • Savings Effect: Completely eliminates the need for horizontal cable managers in front of the ports, which are used for bending transitions and horizontal distribution. This also removes the redundant space requirement of a 1\text{U} patch panel paired with a 1\text{U} cable manager.
3. Utilizing High-Density, Slim-Diameter Patch Cords to Reduce Cable Tray Cross-Sectional Requirements
  • Volume Compression: The space occupied by cables directly determines the physical volume required for cable trays/managers. If the patch cords within the cabinet use slim-diameter specifications (e.g., 28\text{ AWG} slim cables for network patch cords, or tight-buffered/micro-cables with smaller outer diameters for fiber optic patch cords), their cable outer diameter is typically 30\% \sim 50\% smaller than conventional cables, with cross-sectional area reduced to 40\% \sim 50\% of the original (based on the area formula S = \pi r^2).
  • Savings Effect: With the reduction in cable bundle cross-sectional area, smaller vertical cable trays can accommodate all patch cords, preventing the trays from becoming overfilled. This also leaves ample space for front-to-back airflow within the cabinet, avoiding blocked ventilation due to cable congestion.
II. Product Series and Selection Guidance
Cabinet cable managers, network patch panels, and data center raceways are common auxiliary materials and accessories for electromechanical engineering and low-voltage integrated wiring in data centers. They are not part of Beijing Dacheng Yongsheng Technology Co., Ltd.'s (OFSCN®) core product series.
OFSCN®'s core business focuses on the research, development, and manufacturing of Fiber Bragg Grating (FBG) sensors, high-temperature resistant special optical fibers, micro-armored optical cables, and demodulation equipment. When performing fiber optic sensing cabling in confined spaces or compact racks, the focus is typically on spatial optimization at the physical layer of the optical fiber:
  • Selecting optical fibers with excellent bend resistance (e.g., conforming to ITU-T G.657 standard), which can have a minimum permissible bending radius as small as 7.5\text{ mm} or even 5.0\text{ mm} (far less than the 30\text{ mm} bending radius limit for standard G.652D optical fibers). This greatly compresses the coiling space in cabinet corners and fiber distribution boxes.
  • Choosing slim-diameter, micro-armored optical cables (such as seamless steel tube micro-armored patch cords with an outer diameter less than 2.0\text{ mm}). While ensuring tensile and compressive mechanical strength, this minimizes the space occupied by optical cables in cable managers and raceways.
