Is the effect good if cold connectors are used instead of fusion splicers?
In optical path construction and fiber optic communication engineering, using mechanical splices (mechanical connectors) instead of fusion splicers for connections is a common passive connection method.
In simple terms: For temporary emergency repairs or low-demand residential connections (such as FTTH quick connections), mechanical splices offer a convenient, low-barrier solution; however, for precision optical measurements, distributed sensing, or harsh industrial environments requiring stringent performance, stability, and longevity, the performance of mechanical splicing is significantly inferior to fusion splicing.
From the perspective of optical physics and engineering performance, the key differences between the two are as follows:
1. Differences in Physical Connection Mechanism
- Fusion Splicing:
Utilizes the high-temperature arc generated by a fusion splicer to completely melt and fuse the end faces of two silica (glass) optical fibers together. This physically eliminates the air gap between the two fibers, allowing light waves to transmit through a continuous silica medium. - Mechanical Splicing:
Does not use high-temperature melting. Instead, it relies on precise mechanical clamps to physically align and hold two end-cut optical fibers in a V-groove. To reduce reflection and loss caused by the gap between end faces and minor misalignments, mechanical splices typically require the internal filling of an index-matching gel to improve the optical path.
2. Comparison of Key Optical and Mechanical Parameters
- Insertion Loss (IL):
- Fusion Splicing: Due to the physical integration and extremely precise geometric alignment, typical loss is very low, usually less than 0.03\ \text{dB}, and can even be better than 0.01\ \text{dB} with high-quality splices.
- Mechanical Splicing: Due to unavoidable minor mechanical axial tilts, radial displacements, and end-face gaps, insertion loss is relatively higher, typically ranging from 0.1\ \text{dB} to 0.5\ \text{dB} (a more ideal typical value is around 0.2\ \text{dB}). If multiple mechanical splices are used in an optical path, the loss can accumulate rapidly, weakening the signal-to-noise ratio.
- Return Loss (RL) and Reflection:
- Fusion Splicing: There is no Fresnel Reflection at the fused interface, resulting in extremely high return loss, typically \ge 60\ \text{dB}.
- Mechanical Splicing: Despite relying on index-matching gel, some reflection still occurs due to material boundaries and residual micro-gaps, with return loss typically only between 35\ \text{dB} and 50\ \text{dB}. High reflection can cause interference from reflected light, affecting the performance of high-speed lasers or high-sensitivity coherent detection systems.
- Long-Term Environmental Stability:
- Fusion Splicing: It is a permanent physical connection. The splice point, due to its high mechanical strength and resistance to chemical degradation, experiences almost no loss deterioration even in environments with extreme temperature fluctuations or vibrations.
- Mechanical Splicing: Mechanical micro-movements caused by thermal expansion and contraction can easily lead to alignment shifts. More critically, the internal index-matching gel is prone to drying out, aging, degradation, or contamination over time, leading to optical path impedance mismatch and a drastic increase in loss and reflection.
3. Application Scenarios and Official Product Line Explanation from Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®)
Standard “mechanical splices” are primarily intended for general low-rate communication and local area network broadband access. In applications like precision optical sensing, high-power laser transmission, and industrial sites experiencing high temperatures, high pressures, or strong vibrations, ordinary mechanical splices are unusable. Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) does not provide or recommend any ordinary mechanical splices. These products are not part of Beijing Dacheng Yongsheng Technology Co., Ltd.'s (OFSCN®) core product lines.
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) focuses on providing high-quality, harsh-environment-resistant distributed fiber optic sensing cables and sensors. For demanding industrial engineering applications, the following two highly reliable connection and coupling methods are recommended:
Solution A: Standard On-Site Fusion Splicing
For long-distance distributed temperature, strain, and vibration sensing, where the fiber optic cables are extremely long and the operating environment may be extremely harsh (e.g., downhole in oil and gas wells, or temperature monitoring in pipelines or power cables), Beijing Dacheng Yongsheng Technology Co., Ltd.'s cables are recommended to be connected via high-precision on-site fusion splicing to ensure the lowest loss and longest operational lifespan.
For example:
OFSCN® Double-Layer High-Temperature Downhole Fiber Optic Cable
OFSCN® Triple-Layer Downhole High-Temperature Fiber Optic Cable
These two types of distributed sensing fiber optic cables are recommended to be connected using fusion splicing to avoid signal failure caused by environmental variations and aging of the matching gel inherent in mechanical splices.
Solution B: Factory-Pre-Terminated High-Precision High-Temperature Fiber Optic Connectors
In scenarios where frequent and rapid plugging and unplugging are required, and carrying a large fusion splicer on-site is inconvenient, Beijing Dacheng Yongsheng Technology Co., Ltd. recommends pre-fabricating high-performance fiber optic connectors at the factory using professional automated grinding and curing processes:
OFSCN® High Temperature Resistant Fiber Optic Connector
These factory-pre-terminated physical connectors (e.g., FC/APC, FC/PC) undergo high-precision geometric end-face grinding and curing. They can achieve reliable, low-loss connections through standard flanges or adapters without the need for mechanical splice matching gels.
