Why not just use the core diameter—why was this term created? Is it larger or smaller than the physical core?
In the field of fiber optics, the physical core diameter and the Mode Field Diameter (MFD) are distinct concepts. Understanding why MFD is used instead of just the physical core diameter is essential for precise optical engineering, especially when dealing with Single-Mode Fibers (SMF).
1. Why was the term MFD created?
The term Mode Field Diameter was created because light does not stay strictly confined within the physical boundaries of the fiber core. In a single-mode fiber, the light travels as a “mode” (an electromagnetic field distribution).
While the physical core is a mechanical boundary defined by the refractive index change, the optical power actually penetrates into the cladding. Therefore, if you only measured the core diameter, you would be ignoring a significant portion of the light being transmitted. MFD provides a more accurate representation of the “optical size” of the light beam.
2. Is MFD larger or smaller than the physical core?
MFD is always larger than the physical core diameter.
For a standard single-mode fiber (like G.652):
- Physical Core Diameter: Typically around 8 to 9 micrometers (µm).
- Mode Field Diameter (MFD): Typically around 9.2 to 10.4 micrometers (µm) at a wavelength of 1310nm.
The “extra” size represents the “evanescent field”—the portion of light that travels within the cladding immediately surrounding the core.
3. Technical Significance of MFD
MFD is a critical parameter for several reasons:
- Splicing and Coupling: When joining two fibers, MFD mismatch causes higher insertion loss than core diameter mismatch. If the MFDs don’t match, the light distributions won’t align perfectly, leading to power loss.
- Bending Sensitivity: A larger MFD generally means the light is less tightly confined to the core, making the fiber more sensitive to macro-bending and micro-bending losses.
- Wavelength Dependence: Unlike the physical core (which is fixed), MFD changes with wavelength. As the wavelength increases, the MFD increases because the light is less confined and spreads further into the cladding.
For high-precision sensing applications, such as those using OFSCN® Fiber Bragg Gratings (FBG), understanding the MFD is vital for ensuring optimal signal integrity between the sensor and the OFSCN® FBG Interrogator.
If you are working on a specific project involving fiber splicing or sensor integration, feel free to share the environment or requirements for further technical analysis.
