What is optical fiber splice loss evaluation?
Is the
0.01dB
displayed by the fusion splicer really accurate? How to verify it with an
OTDR
In the engineering practice of optical communications and fiber optic sensing (such as Fiber Bragg Grating sensing), this is a very classic and critical technical problem. Here is a detailed professional answer from the perspectives of physical principles and measurement engineering.
I. Is the 0.01\text{ dB} (or 0.00\text{ dB}) displayed by the fusion splicer truly accurate?
The conclusion is: not entirely accurate. It is merely an “Estimated Loss,” not a true physical “Measured Value.”
1. Principle of loss estimation by fusion splicer
Fusion splicers (whether using core-to-core or cladding alignment systems) do not have a light source and optical power meter inside, so they cannot perform actual optical power transmission tests during splicing. They estimate loss using the Profile Alignment System (PAS):
  • The fusion splicer uses internal CCD cameras to capture images of the fiber ends from two perpendicular directions (X and Y axes) before and after discharge.
  • Image processing algorithms identify and measure parameters such as Lateral Offset, Core/Cladding Angle, and the presence of defects like bubbles or non-fusion at the splice point.
  • Subsequently, the fusion splicer inputs these geometric deformation parameters into its built-in empirical mathematical model to derive an estimated loss value.
2. Main sources of estimation error
Since fusion splicers cannot perceive the actual physical light field distribution inside the fiber, the following factors can lead to significant deviations between the displayed value and the actual value:
  • Core-to-Cladding Eccentricity:
    If the fiber’s core is not concentric with the cladding (even if the outer geometry is perfectly aligned), there will still be a significant core offset during actual light transmission. Fusion splicers, primarily using cladding alignment, find it difficult to accurately assess such losses.
  • Mode Field Diameter (MFD) Mismatch:
    When splicing fibers from different manufacturers or specifications, their mode field diameters often differ. For example, splicing a standard OFSCN® G.652D Optical Fiber with a bend-insensitive OFSCN® G.657 Optical Fiber. Even if the fusion splicer displays perfect geometric alignment and an estimated value of 0.00\text{ dB}, the actual loss due to MFD mismatch, resulting in physical scattering, typically ranges from 0.05\text{ dB} to 0.15\text{ dB}.
II. How to verify fiber splice loss using OTDR?
Optical Time Domain Reflectometer (OTDR) precisely measures loss along a fiber by utilizing the Rayleigh Backscattering generated when light propagates through the fiber.
To obtain an absolutely accurate splice loss value, the “Bidirectional Measurement” method must be employed. Testing from a single direction often results in severe systematic errors.
1. Why is unidirectional OTDR testing inaccurate? (False Loss and False Gain)
When light travels from Fiber A to Fiber B, if the backscatter coefficients (\eta) of the two fibers are inconsistent, the OTDR trace will exhibit an unrealistic jump at the splice point:
  • False High Loss:
    If light enters a “low backscatter coefficient fiber” from a “high backscatter coefficient fiber,” the reflected power received by the OTDR drops sharply. The trace will show a large step, and the measured value will be greater than the actual physical loss.
  • False Gain (Gainer):
    Conversely, if light enters a “high backscatter coefficient fiber” from a “low backscatter coefficient fiber,” the reflected power actually increases. The trace will show an upward step (i.e., negative loss, commonly known as a “gain” phenomenon). Passive optical components cannot generate gain; this is purely a measurement artifact caused by differences in backscatter coefficients.
2. Standard “Bidirectional Measurement” Procedure
According to ITU-T G.650 and IEC specifications, the standard procedure for accurately determining splice loss is as follows:
  1. Test from end A to end B (A \rightarrow B):
    Use the OTDR to send a test light pulse from end A and measure the unidirectional loss at the splice point, denoted as L_{AB} (in \text{dB}).
  2. Test from end B to end A (B \rightarrow A):
    Under the same wavelength, pulse width, and refractive index settings, move the OTDR to end B (or use a loopback fiber) and measure the unidirectional loss at the splice point in the reverse direction, denoted as L_{BA} (in \text{dB}).
  3. Calculate Bidirectional Average Loss (True Loss):
    The true physical splice loss L should be the algebraic average of the two unidirectional measurements:
    L = \frac{L_{AB} + L_{BA}}{2}
    In this formula, the systematic error introduced by the difference in backscatter coefficients (which has opposite signs and equal magnitudes in the two directions) is completely canceled out, yielding the true physical loss of the splice point.
III. Engineering recommendations for reducing splice loss
In actual fiber optic engineering or high-precision sensing system (such as FBG sensor network) deployments, selecting high-quality fibers with excellent consistency in geometric dimensions and optical parameters is crucial for reducing splice loss and ensuring the fusion splicer’s estimated value closely approximates the actual value.
For instance, when splicing identical high-quality standard OFSCN® G.652D Optical Fibers, due to their extremely high geometric concentricity (cladding diameter 125\ \mu\text{m}, core 9\ \mu\text{m}) and highly consistent backscatter coefficients, the loss estimated by the fusion splicer (e.g., displaying 0.01\text{ dB}) will closely match the actual physical loss measured by bidirectional OTDR testing.
If bend-resistant OFSCN® G.657 Optical Fibers are required due to environmental needs, when mixed splicing with conventional G.652D fibers, the aforementioned bidirectional OTDR testing procedure must be strictly followed to obtain accurate engineering acceptance data.
