After the sensor is installed, does it need to be cleaned annually?
In fiber optic sensing engineering applications, fiber Bragg gratings (FBGs) or fiber optic temperature/strain sensors, once correctly installed and deployed, typically do not require annual surface scrubbing or routine cleaning maintenance.
The primary reasons and maintenance considerations from the perspective of optical and mechanical packaging principles are as follows:
I. “Maintenance-Free” Characteristics of the Sensor Body
Optical Signal Transmission Mechanism and Internal Sealing
The signal modulation in fiber optic sensors occurs entirely within the fiber core (utilizing the principle of total internal reflection and Bragg reflection wavelength drift). Mature, industrial-grade fiber optic sensors are encapsulated before leaving the factory (e.g., seamless stainless steel tubes, elastic alloy tubes, or polymer encapsulation for complete sealing). The internal fiber is completely isolated from the external environment, and dust or minor surface contaminants will not interfere with the optical path transmission inside the fiber. -
Physical Quantity Transfer Unaffected by Conventional Dust Accumulation
- Temperature Measurement: Metal encapsulation (such as seamless stainless steel micro-tubes) offers excellent thermal conductivity. The impact of conventional environmental dust or surface oxide layers on thermal response is negligible in most engineering applications.
- Strain Measurement: Strain sensors are typically rigidly fixed to the surface/internal structure of the object being measured through welding, clamping, or high-strength adhesives. As long as the fixing anchors and the strain transfer substrate structure are stable, the surface does not require cleaning.
II. The Only Cleaning Scenario to Monitor: Fiber Connector End Faces
Although the sensor body is maintenance-free, the fiber optic active connectors (e.g., FC/APC, ST connectors) within the entire sensing link require adherence to the following maintenance principles:
- Long-Term Fixed Connection State: Once a connector is securely inserted and sealed through a flange adapter, it does not require periodic removal and cleaning.
- Re-plugging/Inspection State: Only during system upgrades, demodulator replacements, or when connectors are disconnected and re-plugged, if the fiber end face is exposed to air and contaminated with dust or oil, it can lead to increased insertion loss or abnormal reflectivity. In such cases, specialized fiber optic cleaning paper/pens must be used to clean the end face before reconnecting.
Summary
After installation and fixation, the fiber optic sensor body is essentially maintenance-free throughout its designed service life and does not require annual scrubbing. It is only necessary to ensure that the mounting base is firm and the armored fiber optic cable leads are not subjected to accidental shear damage from external mechanical forces.
