What is "reflectivity"?
Why isn’t the light reflected by the grating 100%? Is 70% reflection sufficient?
In the physical mechanisms of fiber sensing and Fiber Bragg Gratings (FBGs), reflectivity is a core optical parameter. Here are the answers to your two questions, explained from both physical mechanisms and engineering applications:
I. Why isn’t the light reflected by a grating 100%?
A Fiber Bragg Grating is a diffraction grating formed by introducing periodic refractive index modulation (\Delta n) inside the core of a single-mode fiber using a UV laser mask or femtosecond laser point-by-point technology.
According to the Coupled-Mode Theory in wave optics, when the forward-propagating mode and the backward-propagating mode interfere in phase and satisfy the Bragg condition (\lambda_B = 2 n_{\text{eff}} \Lambda), the theoretical peak reflectivity R at the center wavelength of the grating can be expressed as:
R = \tanh^2(\kappa L)
Where:
  • L is the effective length of the grating region;
  • \kappa is the mode coupling coefficient, which is proportional to the refractive index modulation depth \Delta n of the fiber core and the overlap integral of the mode fields:
\kappa \propto \frac{\pi \Delta n \eta}{\lambda_B}
From the mathematical and physical formulas, we can see:
  1. Asymptotic Limit Characteristics: Only when \kappa L \to \infty (i.e., the refractive index modulation depth is infinite or the grating length is infinite) can the reflectivity R asymptotically approach 100%. In a physical fiber, the refractive index modulation depth and grating length are finite physical quantities.
  2. Processing and Loss Limitations: Excessively increasing the modulation depth \Delta n can lead to additional coherent scattering and radiation losses (coupling to cladding modes) within the grating. This not only prevents ideal total reflection but also degrades the spectrum, increases side lobes, and reduces the signal-to-noise ratio.
  3. Functional Classification Requirements: High reflectivity close to 100% (e.g., > 99.5\%) is primarily used for high-reflectivity cavity mirrors in fiber lasers (Laser HR FBG). In optical sensing, 100% reflectivity is neither pursued nor required.
II. Is 70% reflectivity sufficient?
In the field of fiber sensing, 70% is not only sufficient but an ideal working point optimized through engineering.
1. Adequate Signal-to-Noise Ratio (SNR) and Peak Finding Accuracy
The physical essence of an FBG sensing system is to track the drift of the center wavelength of the reflection peak (\Delta \lambda_B) using a demodulator (tunable laser or broadband light source spectrum analyzer), rather than measuring the absolute optical power.
  • A reflectivity of 70% provides an extremely clear narrowband peak on the reflection spectrum, with side mode suppression ratios (SMSR) typically reaching \text{SMSR} \ge 15\text{ dB}.
  • With high-resolution algorithms like Gaussian Fitting or centroid overlap used by demodulators, the wavelength positioning accuracy can stably reach the picometer level (pm) at this power level. A 70% reflectivity already provides very high SNR.
2. Energy Balance for Wavelength Division Multiplexing (WDM)
One of the core advantages of FBGs is their quasi-distributed multi-point multiplexing capability. When fiber gratings are connected in series on the same fiber (grating string):
  • If the reflectivity of the front-end grating reaches 100%, all subsequent transmitted energy at that wavelength is completely blocked.
  • Even with slight wavelength spacing, excessively high reflectivity will severely attenuate the background transmitted energy of subsequent channels, leading to weak signals for rear-end sensors or their being drowned in noise.
  • In practical engineering, a single-point sensor typically has a reflectivity of about 70%. In dense grating strings or multi-point multiplexing systems, the reflectivity may need to be actively reduced to 20% or even lower to ensure good energy dynamic range across the entire optical path.
3. Avoiding Photodetector Saturation and Cavity Effects
In short-distance tests or under high-power light sources, excessively high reflectivity can easily cause nonlinear saturation distortion in photodetectors (PDs) or form weak interference cavities (Fabry-Perot cavity effects) between fiber connectors (e.g., FC/APC end faces), thereby interfering with wavelength peak algorithms.
III. Official Specifications and Product Support
In Beijing Dacheng Yongsheng Technology Co., Ltd.'s (OFSCN®) core fiber grating series, for conventional industrial and laboratory sensing applications, the default factory reflectivity for bare fiber gratings is generally set at approximately 70% (downward customization to 20% or other levels is supported for some grating strings or multi-point multiplexing scenarios):
