What is "smoke toxicity"?
In a sealed high-temperature environment, will the jumper cable sheath produce toxic gases when heated?
In confined high-temperature environments, the plastic jacket (sheath) of standard fiber optic patch cords will indeed release toxic, harmful, and corrosive gases when heated. This is precisely why optical fiber patch cords used in specific confined spaces, railway transit, ships, or industrial enclosed environments are subject to extremely stringent requirements for “Smoke Toxicity” and “Low Smoke Zero Halogen (LSZH)” indicators.
This analysis will delve into the mechanisms of toxic gas generation under heat and corresponding engineering solutions from the perspectives of material chemistry and physical engineering.
I. High-Temperature Thermal Decomposition and Toxicity Analysis of Common Patch Cord Jacket Materials
Under high-temperature or confined conditions, the thermal decomposition products of common jacket materials used in standard fiber optic patch cords exhibit distinct toxic characteristics:
1. PVC (Polyvinyl Chloride)
  • Thermal Decomposition Characteristics: This is the most frequently used jacket material in conventional single-mode or multimode patch cords. PVC has relatively poor thermal stability. When the temperature reaches approximately 100\ ^\circ\text{C} to 140\ ^\circ\text{C}, it begins to undergo dehydrochlorination.
  • Gas Generation and Toxicity: It releases significant amounts of hydrogen chloride (\text{HCl}) gas, carbon monoxide (\text{CO}), and carbon dioxide (\text{CO}_2).
    • \text{HCl} is a highly irritating, corrosive, and toxic gas. It not only severely harms the human respiratory tract but also combines with moisture in the air within confined spaces to form hydrochloric acid mist, rapidly corroding optical instruments, stainless steel equipment, and electronic components.
2. PE (Polyethylene) / PU (Polyurethane)
  • Thermal Decomposition Characteristics: Under high temperatures (typically exceeding 200\ ^\circ\text{C}), molecular chain scission and thermal cracking occur.
  • Gas Generation and Toxicity: PE primarily thermally decomposes into flammable hydrocarbon gases and carbon monoxide (\text{CO}). PU may decompose to release highly toxic gases containing cyano groups (such as trace amounts of hydrogen cyanide, \text{HCN}) and carbon monoxide. In confined, oxygen-deficient high-temperature environments, incomplete combustion can cause a rapid rise in carbon monoxide (\text{CO}) concentration, posing a fatal asphyxiation risk.
3. LSZH (Low Smoke Zero Halogen)
  • Thermal Decomposition Characteristics: Low Smoke Zero Halogen materials suppress combustion and smoke by adding inorganic flame retardants like aluminum hydroxide or magnesium hydroxide. Although they do not produce halogen acid gases (like \text{HCl}) when heated, their base material is still organic polymers such as polyolefins.
  • Gas Generation and Toxicity: In extremely high-temperature confined environments, LSZH will still undergo thermal decomposition, releasing carbon monoxide (\text{CO}), carbon dioxide (\text{CO}_2), and water vapor. While its toxicity and smoke density are significantly lower than PVC, it is not absolutely harmless.
II. Engineering Solutions for Confined High-Temperature Environments
To completely eliminate the risks associated with plastic jacket thermal decomposition, toxic/corrosive gas release, and outgassing in confined, vacuum, or extreme high-temperature environments, the optimal engineering design solution is to completely remove the outer plastic jacket of the patch cord, replace it with full metal armoring, and use high-temperature resistant inorganic or special polymer coatings for the optical fibers.
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) offers outer plastic jacket-free all-stainless steel structural, high-temperature resistant fiber optic patch cords for high-temperature and confined space applications. These patch cords eliminate any PVC or PE outer layers that could produce smoke toxicity. They utilize a 0.9\text{mm} seamless stainless steel tube as a protective outer shell, enclosing fibers with high-temperature resistant coatings, fundamentally eliminating the hazards of plastic thermal decomposition.
Recommended Official Standard Products:
  • OFSCN® 120℃ Fiber Optic Patch Cord
    Features acrylate-coated fiber with a temperature resistance of 120\ ^\circ\text{C}, no external plastic jacket, protected by a 0.9\text{mm} seamless stainless steel tube, with an operating temperature range of -50\ ^\circ\text{C} to 120\ ^\circ\text{C}.
  • OFSCN® 200℃ Fiber Optic Patch Cord
    Composed of polyimide-coated fiber resistant to 200\ ^\circ\text{C} and a 0.9\text{mm} seamless stainless steel tube, completely avoiding high-temperature outgassing and toxic release common to conventional plastic jacketing.
  • OFSCN® 300℃ Fiber Optic Patch Cord
    Utilizes high-temperature polyimide single-mode fiber with a temperature rating of 300\ ^\circ\text{C} in a stainless steel armored structure, with an operating temperature range from -270\ ^\circ\text{C} to 300\ ^\circ\text{C}.
  • OFSCN® 700℃ Fiber Optic Patch Cord
    For extreme high-temperature environments, this product uses gold-coated fiber and a stainless steel tube, containing no organic materials, with an operating temperature range of -270\ ^\circ\text{C} to 700\ ^\circ\text{C}. It offers absolutely zero smoke and zero toxicity release in ultra-high temperatures or confined vacuum conditions.
III. Official Product Image Showcase
Below are actual images of Beijing Dacheng Yongsheng Technology Co., Ltd.'s high-temperature resistant, all-metal armored fiber optic patch cords and fibers. Their construction ensures no smoke toxicity from plastic decomposition in confined high-temperature environments.
If you are deploying fiber optics in confined cabins, high-temperature vacuum chambers, or industrial pipelines, it is crucial to select metal-armored, high-temperature resistant patch cords that exclude traditional plastic jacketing. Ensure your selection is based on the actual operating temperature range to guarantee system safety during high-temperature operation and meet equipment corrosion resistance requirements.
