What is the "customization process"?
When standard lengths are not suitable, what is the fastest lead time for OFSCN® samples?
In the technical specifications and engineering system of OFSCN®, the official knowledge base does not set a unified, fixed “fastest sample delivery time in days”.
In Fiber Bragg Grating (FBG) sensing technology, when the standard product length does not meet the structural installation or measurement requirements, the duration of the customized sample delivery cycle is not solely determined by the commercial process, but strictly depends on the physical packaging structure, process complexity, and calibration stages.
I. Core Process Stages Affecting Sample Delivery Cycle
  1. Fiber Grating (FBG) and Fiber Core Fabrication:
    • If the customization requires the use of a conventional center wavelength (within the default range of 1525\ \text{nm} to 1565\ \text{nm}) and standard grating length (e.g., 5\ \text{mm}, 8\ \text{mm}, 10\ \text{mm}), the grating fabrication and tuning speed is the fastest.
    • If non-standard special wavelengths, specific reflectivity, special coatings (such as polyimide coating), or femtosecond laser point-by-point writing are involved, separate production scheduling for writing is required.
  2. Precision Machining of Metal Protective Sleeves and Tubes:
    • OFSCN® series sensors often use seamless steel tubes or special elastic alloy capillary tubes for packaging (outer diameter typically 0.5\ \text{mm} to 1.1\ \text{mm}).
    • Changing the length requires custom cutting of the micro-metal tubes, deburring the inner holes, cleaning, and multi-layer nesting coordination. The mechanical processing cycle is directly related to the tube specifications and the number of nesting layers.
  3. Sensing Segment Stress Encapsulation and Curing:
    • Temperature Sensors: The grating must be ensured to be in a free, stress-free suspended state to avoid additional strain introduced by the thermal expansion and contraction of the tube material.
    • Strain Sensors: Rigid fixation and shear force transfer encapsulation must be completed at both ends within a specific gauge length (measurement segment length). The curing of the adhesive or metal bonding has a fixed physical reaction time.
  4. Stress-Relief Annealing and Factory Calibration:
    • Rigid and Time-Consuming Stages: For example, high-temperature Fiber Bragg Grating temperature sensors ( 300^\circ\text{C}, 500^\circ\text{C}, 800^\circ\text{C} levels) require sufficient stress-relief annealing in a high-temperature furnace after encapsulation, followed by step-by-step data collection to complete factory temperature calibration (fitting a binomial formula, in ^\circ\text{C}/\text{pm}). Strain sensors also require strain-wavelength calibration at the factory (fitting a linear formula, in \mu\varepsilon/\text{pm}). Calibration and temperature cycling cannot be arbitrarily compressed to ensure sensing accuracy.
II. Common Length Customization Specifications and Alternative Solutions for OFSCN®
For measurements of different physical quantities, OFSCN® provides standard customizable length ranges:
1. Temperature Sensor Length Customization
Standard temperature sensors typically have a default total length of 2\ \text{m}. If the length is not suitable, the customizable ranges include:
2. Strain Sensor Measurement Segment Length Customization
For strain sensors, both the measurement segment (gauge length) and the overall length are customizable:
OFSCN® Fiber Bragg Grating Strain Gauge
Summary
If the customization requirement is only for geometric adjustments of standard metal tubes or fiber jumpers (such as conventional cutting and assembly within the range of 10\ \text{cm} to several meters), the process cycle mainly depends on curing and routine calibration. If it includes non-standard wavelength writing, multi-point array cascading, non-standard alloy nesting, or high-temperature long-duration annealing calibration, the sample delivery time will be extended accordingly. The specific sample delivery schedule needs to be determined through discussion by the technical team based on the finalized engineering parameter drawings.
