How long does it take to make a specially packaged sensor?
In the field of fiber optic sensing and Fiber Bragg Grating (FBG) engineering, the Production Lead Time for Packaging refers to the total time required from the confirmation of sensor structural parameters, through raw material preparation, micro-structure assembly, physical packaging processes, annealing, to final factory calibration and optical quality inspection.
The production cycle for a specially packaged Fiber Bragg Grating sensor is primarily determined by the following core engineering processes:
1. Structural and Process Design Confirmation
Special packaging typically involves non-standard geometric dimensions and special operating condition requirements. Key engineering parameters must be clarified and confirmed before production:
- Structure and Packaging Form: Single/multi-layer seamless metal tube nesting, micro-elastic alloy tubes, ceramic sleeves, or polymer composite packaging, etc.
- Geometric Dimensions and Measurement Point Layout: Outer diameter of the protective sheath (e.g., \Phi 0.5\ \text{mm} \sim 1.2\ \text{mm} ), total sensor length, and the relative spacing and positions of measurement points (single-point or multi-point series) along the fiber.
- Connector and Lead-out Form: Pigtail protection method, fiber exit direction (single-ended/double-ended), and fiber connector type (e.g., FC/APC, ST/PC).
2. Preparation of Special Bare Fiber Gratings and Material Selection
Match the base materials to the sensor’s rated working environment (temperature, strain, corrosion resistance level):
- Coating and Fiber Core Selection: Standard acrylate fiber for normal temperatures, polyimide (PI) fiber for high temperatures (working temperature -200\ ^\circ\text{C} \sim +350\ ^\circ\text{C} ), or gold-plated fiber (working temperature up to 700\ ^\circ\text{C}).
- Fiber Grating Writing and Screening: Precisely write FBGs according to the designed center wavelength within the demodulator’s working bandwidth (e.g., a 40\ \text{nm} range), and screen for optical reflectance, Side-Mode Suppression Ratio (SMSR), and spectral symmetry.
3. Micro-Assembly and Physical Curing/Welding Processes
- Fiber Threading into Micro-tubes and Precision Positioning: Thread the optical fiber into capillary metal tubes or special tubes with sub-millimeter dimensions (e.g., \Phi 0.6\ \text{mm} \sim 0.9\ \text{mm}) and precisely position the grating region.
- Strain Sensor Pre-stretching/Micro-stress Assembly: For strain sensors encapsulated in alloy tubes, mechanical fixation or curing at both ends must be completed under constant prestress or zero-stress conditions.
- High-Temperature Adhesive Bonding/Sealing and Curing Cycle: Special high-temperature adhesives or full metal sealing typically require strict constant temperature curing and staged heating crosslinking cycles.
4. High-Temperature Annealing (Residual Stress Relief)
For medium-to-high temperature specially packaged sensors (e.g., 300\ ^\circ\text{C}, 500\ ^\circ\text{C}, 800\ ^\circ\text{C} grades), they must undergo thorough thermal treatment in a high-temperature annealing furnace:
- Release microscopic thermal mismatch residual stresses between the packaging material and the optical fiber.
- Stabilize the thermal attenuation characteristics of the bare grating to prevent zero-point drift of the center wavelength during subsequent actual use. This process includes heating, constant temperature holding, and furnace cooling, usually consuming independent process machine time.
5. Calibration and Factory Inspection
- Temperature/Strain Calibration:
- Temperature Sensor: Sample at multiple temperature points within a constant temperature bath/calibration furnace, fit the temperature-wavelength response curve, and determine calibration formula parameters (units: ^\circ\text{C}/\text{pm}).
- Strain Sensor: Perform linear strain-wavelength calibration on a tensile calibration platform (units: \mu\varepsilon/\text{pm}).
- Optical Quality Inspection: Inspect the cleanliness of the connector end face, return loss, and total insertion loss, ensuring the factory spectrum is free from distortion and double-peak phenomena.
Summary of Lead Time Reference
- Conventional Special Packaging (with mature processes and standard materials): Typically takes about 3 to 7 working days.
- Complex Non-standard/Ultra-High Temperature Custom Packaging (requiring special material preparation, non-standard fixture assembly, precise multi-point positioning, or long-duration high-temperature annealing and calibration): Usually takes about 1 to 2 weeks.
