What is the cutoff wavelength of a fiber optic patch cord?
Why can’t a 1310nm jumper be used to transmit 850nm light?
In fiber optics, a “1310nm patch cord” commonly refers to a patch cord manufactured using standard single-mode communication fibers (such as OFSCN® G.652D Optical Fiber or OFSCN® G.657 Optical Fiber).
1310nm single-mode patch cords cannot (or are not recommended) for transmitting 850nm optical signals, primarily due to the fiber’s “Cutoff Wavelength (\lambda_c)” limitation and mismatch in core geometry.
I. Core Physics Principle: Cutoff Wavelength and Normalized Frequency V
Whether a fiber operates in single-mode depends on the fiber’s Normalized Frequency ( V parameter):
V = \frac{2\pi a}{\lambda} \text{NA} = \frac{2\pi a}{\lambda} \sqrt{n_1^2 - n_2^2}
  • a: Fiber core radius (standard G.652D core diameter is approximately 9\ \mu\text{m}, so a \approx 4.5\ \mu\text{m})
  • \lambda: Operating wavelength
  • \text{NA}: Numerical Aperture
  • n_1, n_2: Refractive indices of the core and cladding
In a step-index fiber, the theoretical condition for transmitting only the fundamental mode ( \text{LP}_{01} mode) is:
V < 2.4048
The theoretical cutoff wavelength (\lambda_c) of the fiber is the wavelength at which V = 2.4048:
\lambda_c = \frac{2\pi a \cdot \text{NA}}{2.4048}
  • When the operating wavelength \lambda > \lambda_c, V < 2.4048, and the fiber is in strict single-mode transmission.
  • When the operating wavelength \lambda < \lambda_c, V > 2.4048, and the fiber will support higher-order modes (e.g., \text{LP}_{11}, \text{LP}_{21}, etc.), degenerating into multi-mode transmission.
II. Major Issues with 1310nm Patch Cords Transmitting 850nm Light
1. Single-Mode Degeneration into “Few-Mode Transmission,” Causing Severe Intermodal Dispersion and Interference
  • Cutoff Wavelength Range: The standard cutoff wavelength (\lambda_{cc}) for standard 1310nm single-mode fibers (G.652D/G.657) is typically designed to be between 1180\text{ nm} \sim 1260\text{ nm}.
  • Mode Excitation: When 850nm light is injected, since \lambda \ll \lambda_c, the normalized frequency V is significantly greater than 2.4048. The fiber is no longer a single-mode fiber but becomes a Few-Mode Fiber.
  • Intermodal Interference and Modal Noise: The fundamental mode and higher-order modes propagate at different phase velocities within the fiber and interfere at the receiving end or connectors. Minor vibrations or temperature changes in the fiber cause phase drift among the modes, leading to drastic fluctuations in received optical power and increased signal bit error rates.
2. Higher-order Modes are Extremely Sensitive to Bending, Resulting in Uncontrollable Loss
Lower-order higher modes (e.g., \text{LP}_{11}) excited near the cutoff wavelength have a larger proportion of their energy in the evanescent wave in the cladding. When the patch cord is slightly bent, coiled, or subjected to stress, these higher-order modes are heavily radiated and lost, causing transmission loss to fluctuate wildly with changes in the patch cord’s configuration.
3. Mismatch in Geometry and System
  • If connecting to an 850nm Multi-Mode System (e.g., VCSEL modules):
    850nm multi-mode optical modules typically match 50\ \mu\text{m} (OM2/OM3/OM4/OM5) or 62.5\ \mu\text{m} (OM1) core diameter multi-mode fibers. Using a 9\ \mu\text{m} core diameter 1310nm patch cord for connection results in a significant geometric aperture mismatch between the transmitted light spot and the single-mode fiber core, leading to extremely low light coupling efficiency and huge insertion loss (typically > 10\text{ dB}).
  • If connecting to a dedicated 850nm Single-Mode System:
    Dedicated 850nm single-mode fibers (e.g., 780HP/830HP) are usually designed with a very small core diameter (around 4\ \mu\text{m} \sim 5\ \mu\text{m}) to compress the cutoff wavelength below 800\text{ nm}. Forcibly using a 9\ \mu\text{m} core diameter 1310nm patch cord will also result in high loss and mode distortion due to severe Mode Field Diameter (MFD) mismatch.
III. Summary Comparison
Parameter / Characteristic 1310nm Single-Mode Patch Cord (e.g., G.652D) 850nm Multi-Mode Patch Cord (e.g., OM3/OM4) Dedicated 850nm Single-Mode Patch Cord
Core Diameter Approx. 9\ \mu\text{m} 50\ \mu\text{m} / 62.5\ \mu\text{m} Approx. 4\ \mu\text{m} \sim 5\ \mu\text{m}
Cutoff Wavelength \lambda_c Approx. 1180 \sim 1260\text{ nm} No single-mode cutoff concept (transmits many modes) < 800\text{ nm}
Operating Mode at 850nm Few-Mode (Multi-modal, strong interference) Graded-index multi-mode (low intermodal dispersion) True Single-Mode
Transmission Stability at 850nm Extremely Poor (high modal noise, prone to jitter) Stable (matches 850nm transceivers) Stable (high-precision sensing/laser applications)
Official Product References
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) offers standard communication and high-temperature resistant fiber optic patch cords manufactured to standard telecom and industrial grade fiber specifications:
