What is the effect of "transit vibration"?
Will the bumps on the road during express delivery damage the connectors? How is OFSCN® packaged?
In fiber optic sensing and communication engineering, Transit Vibration typically refers to the dynamic alternating stress and transient acceleration generated during land, air, or sea transport of goods, caused by vehicle bumps, engine resonance, loading/unloading drops, and road impacts.
To address user concerns about whether “bumps during express delivery can damage fiber optic connectors” and related engineering protective measures, the technical principles are analyzed as follows:
I. Potential Physical Impacts of Transit Vibration on Fiber Optic Connectors
The core components of standard fiber optic connectors (such as FC/APC, ST, etc.) are high-precision zirconia (\text{ZrO}_2) ceramic ferrules, inside which a quartz glass fiber with an outer diameter of only 125\ \mu\text{m} is embedded. Under extreme and harsh vibration conditions without protection, potential risks primarily include:
  1. Brittle Damage to the Ferrule End Face: Zirconia ceramic possesses extremely high hardness and wear resistance, but as a brittle material, its edges may experience microscopic chipping upon strong impact without a protective cap.
  2. Micro-wear and Contamination of the End Face: Vibrational friction can cause impurity particles to create micro-scratches on the polished end face (especially the 8^\circ angled spherical surface of APC connectors), directly degrading optical Return Loss and Insertion Loss.
  3. Root Stress Concentration Causing Fiber Breakage: If the transition area at the rear of the connector endures continuous high-frequency bending and alternating loads, stress concentration may occur at the junction between the metal tube and the bare fiber, leading to fatigue micro-crack propagation or even breakage of the internal fiber core.
II. Can Express Delivery Bumps Damage Connectors?
Conclusion: Under standard factory protection and proper packaging conditions, the bumps and vibrations encountered during typical express delivery transport will not damage fiber optic connectors.
Fiber optic connectors are designed to meet stringent industrial standards for shock and vibration resistance (e.g., Telcordia GR-326-CORE). Their components have minimal self-weight (typically only a few grams). Under common road vibration accelerations (usually < 3g) and occasional drops, the inertial forces generated are far below the yield limit of the mechanical structure.
III. OFSCN® Connector Protection and Packaging Engineering Standards
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) strictly adheres to the following protection and packaging processes for its fiber optic Bragg gratings, distributed optical fiber cables, and special fiber optic patch cords before they leave the factory:
  1. Rigid Dustproof and Anti-collision Caps:
    All fiber optic connectors (such as FC/APC) leaving the factory are equipped with elastic or threaded anti-collision and dustproof caps. These caps physically isolate the ferrule end face, ensuring it remains suspended or protected by soft elastic material, thereby preventing any direct rigid impact.
  2. Reinforced Stress Relief Structure:
    OFSCN®'s armored sensors and patch cords commonly utilize seamless stainless steel tubes for encapsulation. They are fitted with thickened strain relief boots or metal transition locking structures at the connector’s rear end. This smoothly disperses external tensile and bending impact stresses, preventing stress concentration from being transmitted to the fragile bare fiber inside.
  3. Coiling and Safe Bend Radius Limitation:
    Fibers and armored steel tubes are coiled circularly within the packaging, adhering to rules well exceeding the limit bend radius (typically with a coiling diameter \ge 150\ \text{mm}). This eliminates static pre-stress within the coil and prevents micro-bending losses or damage to the fiber caused by vibration.
  4. Multi-layer Buffer and Shock Absorption Packaging:
    Internal packaging uses anti-static buffer bags and high-density custom foam materials (EPE/bubble wrap) for point-to-point fixation. This absorbs and attenuates the medium and low-frequency vibration accelerations and impact energy during transit, ensuring the connectors remain stationary within the packaging box without relative movement.
IV. On-site Unpacking and Acceptance Inspection & Engineering Recommendations
When receiving sensor and patch cord products that have been transported via express delivery or logistics, it is recommended to follow these standard procedures:
  1. Initial Check of Outer Packaging Integrity: Confirm that the outer box is not severely crushed, deformed, or punctured.
  2. Retain Protective Caps Until Fusion Splicing or Plugging: Do not remove the protective caps prematurely before formally connecting to the fiber Bragg grating interrogator or test system. This prevents dust contamination at the site.
  3. End Face Cleaning: Before use, it is recommended to clean the ferrule end face with a fiber optic end face cleaner or anhydrous ethanol to ensure no particles adhere during testing.
