The effective refractive index is a critical parameter in calculating the Bragg wavelength. What factors influence its value?
The effective refractive index ($n_{eff}$) of an Fiber Bragg Grating (FBG) is indeed a critical parameter for calculating the Bragg wavelength (λB = 2neffΛ). Several factors influence its value:
- Fiber Core and Cladding Refractive Indices: The intrinsic material properties and the refractive index contrast between the fiber’s core and cladding are primary determinants.
- Fiber Geometry: The diameter of the fiber core significantly influences how light is confined and thus affects the effective refractive index.
- Wavelength of Light (Dispersion): The effective refractive index is wavelength-dependent, a phenomenon known as material and waveguide dispersion.
- Mode of Propagation: For single-mode fibers, the effective refractive index is generally associated with the fundamental propagating mode. In multimode fibers, different modes will have different effective refractive indices.
- Temperature: Changes in temperature alter the refractive index of the fiber material due to the thermo-optic effect.
- Strain/Stress: Applied strain or stress can modify the refractive index through the photoelastic effect.
All OFSCN® Fiber Bragg Gratings and FBG sensors are designed with these fundamental optical properties in mind to ensure stable and accurate sensing performance.
Here is an image of an OFSCN® Polyacrylate Fiber Bragg Grating (bare):
You can find more technical details about our core FBG products here:
OFSCN® Polyacrylate Fiber Bragg Gratings / Fiber Bragg Grating Strings (bare)
