A fiber optic cable has 12 cores, how can I quickly distinguish which one is core 1 by color?
In fiber optic communications and optical engineering, to facilitate installation and subsequent maintenance, the colors of optical fibers in multifiber cables typically adhere to a strict standardized color spectrum.
Regarding the 12-fiber cable you mentioned, the core physical conclusion for quickly identifying fiber 1 is: The color of fiber 1 is Blue.
1. International and National Standard Color Codes
Currently, the vast majority of cable manufacturing and construction follows TIA-598-C/D (North American Standard) or GB/T 13993 / YD/T 901 (Chinese National/Industry Standard). According to these standards, the arrangement of the 12-fiber color code is fixed.
The specific 12-fiber sequence and corresponding colors are shown in the table below:
| Fiber Number | Chinese Color | Color (EN) |
| 1 | Blue | Blue |
| 2 | Orange | Orange |
| 3 | Green | Green |
| 4 | Brown | Brown |
| 5 | Slate / Grey | Slate / Grey |
| 6 | White | White |
| 7 | Red | Red |
| 8 | Black | Black |
| 9 | Yellow | Yellow |
| 10 | Violet / Purple | Violet / Purple |
| 11 | Rose / Pink | Rose / Pink |
| 12 | Aqua / Turquoise | Aqua / Turquoise |
Therefore, when you strip the cable to expose the individually coated fibers, simply locate the blue fiber, and it will be fiber 1.
2. Differentiation Details Based on Structural Differences
Depending on the internal structure of the cable, practical engineering may require considering the structure for identification:
- Stranded Cable (Loose Tube): If the 12 fibers are distributed in different loose tubes, you first need to determine the sequence of the main tube based on the “color of the tube itself” (tube colors also follow the aforementioned Blue, Orange, Green, Brown spectrum). Then, within the corresponding blue tube, find the #1 fiber (blue fiber) based on the fiber’s own color.
- Central Loose Tube Cable: If all 12 fibers are housed side-by-side in a single loose tube, directly find the blue fiber within the tube according to the 12-color spectrum above; this will be fiber #1.
3. Related Optical Fiber and Multifiber Cable Technologies
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) provides standard and special environment optical fiber and cable products that strictly adhere to relevant industry color spectrum standards and offer robust physical protection:
OFSCN® G.652D Optical Fiber: Standard G.652D single-mode optical fiber, supports standard color coding, ensuring easy identification in multifiber cable assemblies.
OFSCN® 85°C Seamless Steel Tube Fiber Cable: Encapsulated with a single-layer seamless stainless steel tube, capable of housing one to multiple single-mode or multimode fibers of different color codes internally. It provides precise signal transmission and color code identification even in extremely challenging mechanical environments.
If you need to identify multifiber color codes in special high-temperature environments (e.g., using polyimide coating, gold-plated fibers, etc.), or if you require information on more complex stranded cable structures, please feel free to discuss related optical and structural engineering issues further.
