What is the lifespan of an optical fiber?
How many years can a fiber optic cable theoretically last when buried underground? Will it age like plastic?
An optical fiber buried underground typically has an industrial design life (or engineering life) of 20 to 25 years. In ideal geological environments with proper laying specifications and good protection, the actual service life can reach 30 to 50 years or even longer.
The “aging” mechanism of optical fibers is fundamentally different from that of ordinary plastic products. Here is a detailed analysis of the physical and chemical mechanisms behind optical fiber aging and lifespan:
I. The Glass Core Itself: Does Not “Degrade” Like Plastic, But Suffers “Stress Corrosion”
The core of an optical fiber is made of high-purity silicon dioxide (SiO_2) glass. Chemically, inorganic glass is an extremely stable three-dimensional network structure. It does not degrade due to ultraviolet light, oxidation, or microbial action like organic plastics (i.e., what laypeople call “rotting”).
However, glass undergoes the following physical degradations macroscopically and microscopically:
1. Subcritical Crack Growth (Mechanical Aging)
During the fiber drawing and laying process, microscopic cracks (Griffith defects) inevitably form on its surface.
When the optical fiber is buried underground and subjected to minute tensile or bending stresses (denoted as S), these microcracks grow extremely slowly under stress induction. This physical mechanism is known as Subcritical Crack Growth. When the crack depth reaches a critical size, the fiber will suddenly break.
2. Moisture-Accelerated Chemical Stress Corrosion
The humid underground environment accelerates the aforementioned process. Water molecules (H_2O) at the crack tips react with the silicon dioxide bonds (Si-O-Si):
Si-O-Si + H_2O \rightarrow 2(Si-OH)
This reaction causes the chemical bonds of silicon dioxide to break, greatly reducing the energy required for crack propagation, leading to fiber fracture at lower stresses.
3. Hydrogen Loss (Transmission Attenuation Aging)
Anaerobic bacterial activity or electrochemical corrosion of metal armoring in the underground environment produces trace amounts of hydrogen gas (H_2). Hydrogen molecules gradually diffuse and penetrate into the glass.
  • Physical Absorption: Hydrogen molecules exist as free molecules within the glass matrix, causing absorption loss.
  • Chemical Bonding: Under certain conditions, hydrogen reacts with defects in the glass to form hydroxyl groups (-OH). Hydroxyl groups exhibit a very strong absorption peak around 1383\text{nm}. This leads to a significant increase in the fiber’s transmission attenuation (loss), weakening the signal until the fiber is considered “scrapped” in a communication sense.
II. The Protective Coating: Does Age Like Plastic
When optical fibers are in use, a polymer protective layer (coating) must be applied over the glass cladding, most commonly acrylate.
This organic coating does indeed age like plastic. Under long-term underground conditions of moisture, chemical acidity/alkalinity, and temperature cycles, acrylate can undergo hydrolysis, hardening, becoming brittle, or peeling off. Once the coating ages and fails, the fragile glass core is directly exposed to underground moisture and mechanical stress, leading to an exponential decrease in the optical fiber’s lifespan.
III. How to Extend the Lifespan of Optical Fibers? (Industrial Technical Solutions)
In ordinary terrestrial communication networks, standard single-mode optical fibers that comply with international standards can meet the lifespan design requirements of over 25 years, for example:
OFSCN® G.652D Optical Fiber
However, in special industrial environments with higher temperatures, harsh acidity/alkalinity, high humidity, or high stress, ordinary polyacrylate coatings will rapidly age and fail. To extend the actual service life of optical fibers, specialized fiber technologies are typically employed:
1. High-Temperature Resistant/Anti-Aging Polyimide-Coated Optical Fibers
Compared to ordinary acrylate, polyimide offers extremely high thermal and chemical stability, along with superior tensile strength and corrosion resistance. For example:
OFSCN® 200℃ Polyimide Optical Fiber
2. Metal-Coated Optical Fibers (Inorganic Gas-Sealing Layer)
To achieve near-permanent protection against moisture and hydrogen penetration, a metal layer (such as gold) is directly plated onto the glass surface. The metal coating not only completely eliminates the risk of organic polymer aging but also provides a perfect physical hermetic barrier, thoroughly blocking the ingress of moisture and hydrogen gas to the internal silicon dioxide. This greatly extends the mechanical and optical lifespan of the optical fiber in extremely harsh environments. For example:
OFSCN® Gold-coated Optical Fiber
In summary, optical fibers themselves do not rot like plastic, but their underground lifespan is constrained by a combination of stress corrosion, hydrogen loss due to moisture, and the aging of the outer plastic coating. By adopting specialized coating materials or metal encapsulation, the physical lifespan and optical performance of optical fibers can be maintained for an extremely long industrial cycle.
