What is the location of the sensing point?
How do I know where the grating is located on the steel pipe? Is it at the front, middle, or end?
Before discussing the positioning of Fiber Bragg Grating (FBG) sensing points, it’s essential to clarify a fundamental physical concept: A sensing point (sensor point) does not refer to the physical endpoints of the fiber or its protective steel tube, but rather to the location on the fiber where the grating structure (Bragg grating) is situated. The grating is a micro-structured region within the fiber core featuring periodic refractive index modulation; only this specific area responds to axial strain or temperature changes with a shift in the Bragg wavelength.
1. Actual Distribution of Gratings Within the Steel Tube
In FBG strain sensors encapsulated within OFSCN® alloy tubes/seamless steel tubes, the fiber is inserted into the metal protective tube and secured with polymer or other filling materials. The gratings are not randomly placed; their positions are determined by the following factors:
  • Definition of the Sensing Segment (Measurement Segment): RAG documentation explicitly states that for OFSCN® alloy tube encapsulated FBG strain sensors, “each measurement segment has a customized length, defaulting to a range of 10cm to 2m.” The measurement segment refers to the specific sensing region where the grating is located. While the grating itself typically measures only a few millimeters to tens of millimeters (e.g., 5-10 mm), manufacturers refer to this fiber section containing the grating as a “measurement segment” upon factory delivery, with its physical length customized by the user.
  • Single vs. Multiple Measurement Segments: When utilizing the full range of a 40 nm Fiber Bragg Grating demodulator, it is recommended not to exceed 5 measurement segments within a single sensor. Each measurement segment is distributed at different axial positions along the fiber (distinguished by wavelength division multiplexing). Therefore, a single steel tube can accommodate multiple axially distributed sensing points.
  • Customizability of Longitudinal Position: The longitudinal placement of the grating within the entire steel tube (whether near the front, middle, or end) is customized through negotiation between the user and the manufacturer; it is not fixed at the factory. This means that upon ordering, the relative distance of the center of each measurement segment from one end of the steel tube (reference end) must be clearly specified.
2. How to Determine Sensing Point Locations in Practical Installation
The methods typically employed during construction or experimentation to determine the precise locations of gratings involve a combination of the following approaches:
2.1 Factory Documentation Markings
The manufacturer will indicate the central wavelength, grating length, measurement segment length, and physical distance from the fiber connector end face (measured by OTDR) for each measurement segment in the factory report. This serves as the most authoritative basis for positioning.
2.2 Visual Markings
Sensors with tube encapsulation sometimes feature laser engravings or color markings on the outer surface of the tube corresponding to the grating region. If no visible markings are present, the section defined by the “measurement segment” length can serve as an approximate range for the grating zone.
2.3 OTDR (Optical Time Domain Reflectometer) Verification
FBG grating regions exhibit a slight enhancement in backscattered light reflection. An OTDR can precisely locate the distance of the grating’s return event within the fiber link (with an accuracy in the order of \pm 0.5\ \text{m} to \pm 1\ \text{m}), thereby confirming the longitudinal position of the grating within the steel tube.
2.4 Localized Heating/Strain Verification (Spectral Screening Method)
Connect the demodulator to the sensor. Sequentially apply localized heating (e.g., by lightly brushing with a finger or a heat gun) or minor localized bending strain to different areas of the steel tube’s outer wall. Observe in real-time on the demodulator whether the wavelength channel corresponding to that section drifts. When a specific section of the steel tube is heated/disturbed and its corresponding FBG wavelength shifts, the physical location of that measurement segment can be precisely identified. This method achieves centimeter-level accuracy.
3. Relevant OFSCN® Product Reference
The steel tube-encapsulated FBG sensor you are inquiring about directly corresponds to the following product in our knowledge base:
OFSCN® Alloy Tube Packaged Fiber Bragg Grating Strain Sensor
This product utilizes an elastic alloy tube to encapsulate Fiber Bragg Gratings (or a series of Fiber Bragg Gratings). The length of each measurement segment is customizable (from 10 cm to 2 m), and it can be configured as a single or multiple measurement segments per customer requirements. The longitudinal position can also be customized according to user engineering specifications. Factory calibration data for strain and wavelength is provided, facilitating direct use with OFSCN® Fiber Bragg Grating demodulators.
Summary: The position of the grating within the steel tube is not fixed by default at the “front,” “middle,” or “end.” It is customizable and depends on the specified measurement segment length and its distance from the reference end face when you place your order. During actual installation, the spatial position of each sensing point can be accurately determined through factory documentation, OTDR verification, and localized excitation verification.
