If the patch cord is bent at a sharp angle, will the optical signal “leak” out from the inside?
Yes, if a fiber patch cord is bent at an angle sharper than its specified Minimum Bend Radius, the optical signal will indeed “leak” out.
In technical terms, this phenomenon is known as Macrobending Loss.
Technical Explanation
Optical fibers transmit data using the principle of Total Internal Reflection (TIR). Light travels through the core by bouncing off the cladding at specific angles. When the fiber is bent too sharply:
- The angle at which the light hits the core-cladding interface changes.
- The light no longer meets the conditions for total internal reflection.
- Instead of reflecting back into the core, the light penetrates the cladding and radiates outward (leaks), leading to signal attenuation or complete loss of communication.
Factors Influencing the Bend Radius
The degree of “leakage” depends on several factors:
- Fiber Type: Standard single-mode fibers (like G.652.D) are more sensitive to bending. Bend-insensitive fibers (BIF), such as the G.657 series, are designed to handle much tighter radii without significant leakage.
- Wavelength: Longer wavelengths (e.g., 1550 nm or 1625 nm) are generally more susceptible to bending losses than shorter wavelengths (e.g., 1310 nm).
- Coating and Jacketing: While the outer jacket provides physical protection, the optical leakage happens at the core-cladding boundary inside.
DCYS (OFSCN®) Solutions
At Beijing Dacheng Everlight Technology Co., Ltd. (OFSCN), we specialize in high-durability sensing and communication fibers. For applications requiring tight routing or harsh environments, we utilize specialized fibers and protective structures.
For example, our OFSCN® Seamless Steel Tube Encapsulated Fiber Optic Cables provide excellent mechanical protection to ensure the internal fiber is not subjected to extreme mechanical bending beyond its limits.
You can find more detailed technical specifications regarding fiber protection and sensing cables here:
OFSCN® Fiber Optic Cables and Sensors
If you are designing a system and need to know the specific minimum bend radius for a particular OFSCN® product, please let me know the operating environment or the specific model you are considering.
