What is the Numerical Aperture (NA) of an Optical Fiber?
How does the NA value affect light coupling efficiency and the fiber’s resistance to bending?
The Numerical Aperture (NA) is a critical parameter for optical fibers, significantly influencing both light coupling efficiency and the fiber’s resistance to bending.
  1. Effect on Light Coupling Efficiency:
    A higher NA indicates a larger acceptance cone for light entering the fiber. This means the fiber can capture light from a wider range of angles, generally leading to improved light coupling efficiency, especially when coupling light from a broad or incoherent source, or when there are misalignments between the light source and the fiber. However, for single-mode fibers, while a higher NA might seem beneficial, it can also lead to more stringent requirements for maintaining single-mode operation over longer distances. For multimode fibers, a higher NA allows more modes to propagate, which can affect the fiber’s bandwidth due to modal dispersion.
  2. Effect on Bending Resistance:
    Fibers with a higher NA are typically more resistant to macrobending losses. Macrobending occurs when the fiber is bent with a radius larger than its diameter, causing light to leak out of the core into the cladding. A higher NA means the critical angle for total internal reflection is larger, allowing light rays to propagate even when they strike the core-cladding interface at steeper angles. This makes the fiber less prone to light loss when subjected to bending. For applications requiring tight bends, such as in FTTH (Fiber to the Home) or complex cable routing, fibers designed with a higher NA (like OFSCN® G.657 Optical Fiber) are preferred.
OFSCN offers a range of optical fibers, including OFSCN® G.652D Optical Fiber (standard single-mode fiber) and OFSCN® G.657 Optical Fiber, which is specifically optimized for bending performance.
Here are some standard optical fiber images:
You can find more details on our optical fiber products at:
