What is the "polarity" issue?
Why is the device sometimes not connected even when the jumper is properly connected? Is the fiber optic cross-connected?
One of the most common reasons for a failure to establish communication between devices, despite the physical integrity of the jumper cable and the cleanliness of the fiber end-face, in fiber optic communication and sensing networks is a “Polarity” issue, meaning the transmitter and receiver are not correctly matched.
This is directly related to whether the fiber is “crossed.” The following provides a rigorous academic and engineering analysis from the perspective of physical principles, standard polarity classifications, and troubleshooting methods:
I. The Physical Essence of Polarity Issues
Bidirectional fiber optic communication (duplex communication) systems require a closed loop on the physical link. This means the transmit signal channel on one end must be connected to the receive signal channel on the other end:
  1. Transmitter (Tx): Responsible for modulating electrical signals into optical signals and transmitting them.
  2. Receiver (Rx): Responsible for receiving optical signals transmitted from the opposite end and converting them into electrical signals.
For devices to connect and communicate normally, the physical link must strictly adhere to the following:
A Tx on one end must connect to an Rx on the other end; simultaneously, an Rx on one end must connect to a Tx on the other end.
If the fiber is not correctly “crossed” during cabling, it will result in:
A Tx on one end connecting to the Tx on the opposite end, and an Rx on one end connecting to the Rx on the opposite end. Because the transmitters are facing each other and the receivers are facing each other, no optical signal is received, leading to a complete failure of the physical link. This is a typical Polarity Error.
II. Standard Polarity Classifications for Duplex Patch Cords
In fiber optic communication standards (such as TIA-568), duplex fiber patch cords are mainly divided into the following two polarity connection methods:
1. Crossover Patch Cord (A-to-B)
This is the most common and versatile standard duplex patch cord.
  • Physical Structure: The fibers are crossed internally within the patch cord. Position A on one end is physically connected to Position B on the other end.
  • Application Scenario: When you use a single crossover patch cord to directly connect two transceivers (optical modules), it automatically ensures that the Tx on one end accurately corresponds to the Rx on the other end.
2. Straight-Through Patch Cord (A-to-A)
  • Physical Structure: The fibers are not crossed between the two ends. Position A on one end connects to Position A on the other end, and Position B connects to Position B.
  • Application Scenario: Straight-through patch cords are typically not used for direct device-to-device connections. They are primarily used in complex structured cabling systems. In these systems, patch panels, backbone fiber optic cables, and multi-fiber components (such as MPO/MTP) already incorporate the crossover logic. In such cases, straight-through patch cords must be used at the termination points to achieve the final polarity balance for the entire link. Direct use for device
