How to ensure that the connector is not easily pulled off before leaving the factory?
In optical communication and fiber sensing engineering, ensuring that fiber optic jumper connectors are not pulled out during installation and use is a systematic project involving structural mechanics design, precision processing technology, and strict factory quality assurance (QA).
To achieve high reliability and pull-out resistance of connectors before leaving the factory, the following core technical dimensions are mainly used for assurance and verification:
I. Structural Design and Pull-out Resistance Mechanics Principle (Mechanical Path Diversion)
In terms of physical design, when a fiber optic jumper is pulled, the fragile glass fiber must never be used as a load-bearing component. All external pulling forces must be borne by the strength members inside the cable and transmitted directly to the metal tailpiece or housing of the fiber optic connector, thus bypassing the fiber.
1. Traditional Kevlar Crimping Process
For jumpers used in conventional environments, such as OFSCN® Standard Fiber Patch Cord, they are filled with high tensile strength Kevlar fibers (Aramid/Kevlar Yarn).
- Process Control: During assembly, the outer jacket is stripped, the Kevlar fibers are evenly distributed around the metal tailpiece of the connector, and then a specialized crimping tool is used to precisely crimp the metal crimp ring.
- Mechanical Effect: The tensile force is transmitted from the cable jacket to the Kevlar, and then directly to the connector body through the crimp ring, effectively protecting the internal fiber.
2. Full Metal Armor and Steel Wire Rope Anchoring Process (Metal Reinforcement)
For high-strength, industrial-grade, or harsh outdoor environments, the tensile strength and crush resistance of Kevlar are often insufficient. In such cases, all-metal protective structures such as seamless stainless steel tubes and stainless steel wire ropes are used. For example:
- OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord: Uses a 0.6mm seamless stainless steel tube, with a tensile strength of >150N and compressive strength of >240Mpa.
- OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord: Uses a galvanized steel wire rope structure combined with a 1.0mm seamless stainless steel tube, forming an all-metal structure with an astonishing tensile strength of >1500N.
- OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord: Tensile strength up to >1200N.
In these high-strength jumpers, the stainless steel tube or steel wire rope is locked to the metal connector through high-strength mechanical sleeve swaging, argon arc welding, or special fasteners. This forms an integrated rigid connection between the entire connector and the cable body, physically eliminating the possibility of easy pull-out.
3. High-Temperature Adhesive Curing Inside Ceramic Ferrule (Epoxy Curing)
When the bare fiber passes through the zirconia ceramic ferrule, it must be completely cured using high-quality epoxy resin (such as the commonly used 353ND thermosetting adhesive) in a high-temperature curing oven.
- The cured adhesive securely locks the fiber within the micro-pores of the ceramic ferrule, preventing relative displacement of the fiber under external force (i.e., the “piston effect” or slippage).
II. Quality Inspection and Tensile Strength Verification Before Factory Delivery (QA)
To ensure that every jumper meets the design specifications before leaving the factory, factories typically perform strict tensile testing and screening (Proof Testing) in accordance with international and industry standards such as Telcordia GR-326-CORE and TIA-455-6 (FOTP-6):
1. Straight Pull Test / Proof Test
- Test Method: The connector and cable body of the jumper are respectively fixed in the clamps of a tensile testing machine, and a specific tensile force (axial load) is applied at a specified speed.
- Test Limits:
- Standard Kevlar jumpers generally undergo a test load of 50N ~ 100N for a certain period (e.g., 5s ~ 10s).
- Armored and steel wire rope jumpers are subjected to higher range pull tests (sampling or 100% inspection) according to their design specifications (e.g., 150N, 1200N).
- Pass/Fail Criteria: After the tensile force is removed, there should be no mechanical loosening, jacket retraction, or fiber pull-out at the connector.
2. Side Pull / 90-Degree Pull Test
- Simulates the pulling force experienced by a fiber optic jumper when bent at a right angle during field installation. During testing, the cable is subjected to a tensile force at a 90-degree angle relative to the connector (e.g., 19.6N). This test primarily verifies the tolerance of the connector’s boot and crimped area to bending and stretching.
3. Optical Performance Monitoring under Load
- Dynamic Monitoring: While applying the tensile force, the jumper is connected to a light source and an optical power meter (or insertion loss tester) to monitor the changes in insertion loss (IL) and return loss (RL) in real-time.
- Physical Indicators:
- Under Load: The fluctuation of optical performance must be within the extremely small range allowed by the standard (e.g., IL change \le 0.2\text{dB}).
- After Load Release: The optical parameters must recover to the initial baseline state 100%. This indicates that the fiber itself has not undergone permanent mechanical strain or micro-bending compression when subjected to the tensile force.
Through a rigorous closed-loop process from “mechanical crimp locking with Kevlar/steel wire”, “high-temperature curing of adhesive within the ferrule”, to the final “dual verification of factory pull-out resistance and real-time optical performance”, safety hazards such as the connector being easily pulled out are completely eliminated before factory delivery.
