What is the "torsional limit" of an optical fiber?
If you twist a fiber optic cable like a pretzel, how many twists can it withstand before breaking?
The fracture behavior of optical fibers when subjected to torsion is a classic problem in material mechanics involving the torsion of solid shafts and brittle fracture. To answer the question ‘How many twists can a fiber withstand before breaking?’, it is crucial to understand that the absolute number of torsion twists a fiber can endure is not a fixed absolute value, but rather a physical quantity directly proportional to its length (gauge length) and inversely proportional to the fiber diameter.
I. Physical Mechanism and Computational Model
Silica glass optical fibers are typical linear elastic brittle materials. When a fiber of length L and cladding radius r is subjected to a torsion angle \theta (unit: \text{rad} ), the outer surface of the fiber experiences the maximum engineering shear strain \gamma_{\text{max}} :
\gamma_{\text{max}} = \frac{r \cdot \theta}{L}
According to the analysis of pure shear state in elasticity, pure torsion generates maximum principal tensile stress (Principal Tensile Stress) \sigma_1 = \tau_{\text{max}} = G \cdot \gamma_{\text{max}} (where G is the shear modulus of silica glass, approximately 31\ \text{GPa} ) at spiral angles of 45^\circ with respect to the fiber axis. This stress is equal in magnitude to the maximum shear stress.
Fracture failure in silica optical fibers is determined by the unstable extension of microscopic surface cracks under principal tensile stress (Griffith’s brittle fracture theory).
II. How Many Twists Can It Actually Withstand? (Typical Estimation)
For high-quality standard silica single-mode fibers with intact coatings:
  • Cladding Radius r = 62.5\ \mu\text{m} (corresponding to an outer diameter of 125\ \mu\text{m} )
  • Ultimate Shear Strain \gamma_{\text{fail}} is typically around 1.5\% \sim 2.5\% (i.e., 0.015 \sim 0.025\ \text{rad} )
Let N be the total number of twists (where 1\ \text{twist} = 2\pi\ \text{rad} ). The formula for the twist rate (number of twists per unit length) at fracture is:
\frac{N}{L} = \frac{\gamma_{\text{fail}}}{2\pi \cdot r}
Substituting standard parameters for calculation:
  • Ultimate limit per unit length: Approximately ** 38 \sim 64\ \text{Turns per Meter} **.
Examples of Fracture Twists for Common Lengths:
  1. A 10\ \text{cm} length of fiber: Will experience brittle fracture after approximately ** 4 \sim 6\ \text{twists} **.
  2. A 1\ \text{m} length of fiber: Can withstand approximately ** 40 \sim 60\ \text{twists} **.
  3. A 10\ \text{m} length of fiber: Theoretically, it can be twisted over ** 400\ \text{twists} **, assuming uniform tension distribution.
III. Key Factors Affecting Torsion Limit
  1. Fiber Outer Diameter (Cladding Diameter):
    Surface strain is directly proportional to the radius r. Thinner fibers (e.g., specialty fibers with a cladding diameter of 80\ \mu\text{m} ) can increase the ultimate torsion twist limit by approximately 56\% compared to standard 125\ \mu\text{m} fibers.
  2. Surface Defects and Stripping Quality:
    If the fiber coating is mechanically removed, microscopic scratches caused by stripping pliers will create severe stress concentrations, causing the ultimate torsion twist limit to drop to 10\% \sim 20\% of the defect-free state.
  3. Combined Stresses (Tension-Torsion Coupling / Bending-Torsion Coupling):
    If axial tension or bending is applied simultaneously with torsion, the principal tensile stress will be superimposed, leading to a significant reduction in the fracture torsion twist limit.
  4. Optical Performance Degradation (Failure before physical fracture):
    From a purely optical perspective, before the fiber physically breaks, the photoelastic effect caused by torsion introduces significant circular birefringence (rotary effect) and linear birefringence perturbations. This leads to severe rotation of the state of polarization (SOP) and causes spectral broadening or peak splitting in sensors like Fiber Bragg Gratings (FBGs). The permissible
