Why is the sensor head ground to a needle point? Is it to pierce into the object?
In sensor engineering and packaging design, the process of shaping the front end of a sensor probe into a needle-like or beveled tip is known as Tip Sharpening.
Your understanding is correct: in specific engineering and medical measurement scenarios, tip sharpening the tail or front end of a sensing unit is indeed primarily intended to facilitate penetration and entry into an object or tissue for measurement.
I. Physical Principles and Technical Functions of “Tip Sharpening”
Reducing Penetration Resistance and Minimizing Medium Damage
In biomedical applications (such as muscle/soft tissue puncture force measurement), or for measurements within soft colloids or soil, the probe needs to penetrate the medium. According to the basic pressure formula:
P = \frac{F}{S}
Where P is pressure, F is force, and S is the contact area. Tip sharpening significantly reduces the contact area S at the tip. This allows a sufficient pressure P to be generated to cut or pierce the medium with a minimal applied force F , thereby reducing penetration resistance and minimizing trauma or damage to the internal structures of the measured object. -
Enhancing Spatial Positioning Accuracy and Resolution
Flat-headed probes can lead to an averaging effect over the contact surface when touching or entering a medium. A sharpened, needle-like probe can concentrate the measurement action point to a very small spot, enabling precise point-to-point positioning and mechanical parameter measurement within a microscopic area.
II. Related OFSCN® Official Products
Within Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®)'s product line, the sensing unit of the OFSCN® Fiber Bragg Grating 3D Force Sensor can be chosen with either a flat-end structure or a sharpened tip (for easier penetration).
This product is commonly used for multi-directional pressure measurement on solid surfaces and for multi-directional puncture force measurement in the medical industry. Its sensing unit consists of a hard alloy base material and 3 fiber grating measurement segments arranged longitudinally at 120^\circ intervals along the circumference of the base. It is available in various packaging forms, including standard and pen-style.
