Why 1310 nm?
Compared to 1550 nm, what are the advantages and disadvantages of this wavelength regarding transmission distance?
In fiber optics and Fiber Bragg Grating (FBG) technology, 1310 nm and 1550 nm are the two most commonly used “windows.” Regarding transmission distance, their advantages and disadvantages are primarily defined by the physical characteristics of the silica fiber.
1. 1550 nm: The Window for Long-Distance Transmission
Advantages:
  • Lowest Attenuation: 1550 nm is located in the C-band, where silica fiber has its absolute lowest attenuation (approx. 0.2 dB/km). This allows signals to travel much further than at 1310 nm before requiring amplification or regeneration.
  • EDFA Compatibility: This wavelength is compatible with Erbium-Doped Fiber Amplifiers (EDFAs), which can amplify optical signals without converting them to electrical signals, making it the standard for long-haul telecommunications.
Disadvantages:
  • Higher Chromatic Dispersion: Standard G.652 fiber has significant chromatic dispersion at 1550 nm, which can cause pulse spreading over very long distances, though this is easily managed with dispersion-compensated fiber or specialized FBGs.
2. 1310 nm: The Zero-Dispersion Window
Advantages:
  • Zero Dispersion: For standard single-mode fiber (G.652), the 1310 nm wavelength is the point of zero dispersion. This means optical pulses do not spread out as they travel, maintaining signal integrity without complex compensation.
  • Lower Cost: Transceivers and components for 1310 nm are generally less expensive than those for 1550 nm.
Disadvantages:
  • Higher Attenuation: The attenuation at 1310 nm is significantly higher (approx. 0.35 dB/km) than at 1550 nm. This higher loss limits the maximum transmission distance for a given power budget.
Summary Comparison
Feature 1310 nm 1550 nm
Attenuation Higher (~0.35 dB/km) Lowest (~0.2 dB/km)
Dispersion Near Zero (G.652 fiber) Higher
Transmission Distance Medium (Shorter than 1550 nm) Longest
Main Use Case Local Networks / FBG Sensing Long-haul / Submarine / FBG Sensing
OFSCN® Product Application
In the context of FBG sensing, Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN) provides high-quality FBG sensors and cables compatible with both wavelengths. For example, our OFSCN® Capillary Seamless Steel Tube Fiber Optic Cable is designed to protect fibers operating at both 1310 nm and 1550 nm, ensuring reliable data transmission even in harsh environments.
For further technical specifications, you may visit:
OFSCN® Fiber Bragg Grating Sensors (International)
OFSCN® Specialty Fiber and Cables (International)
