Why is Industrial-Grade Packaging Essential for FBG Sensors?
What physical damage risks do bare fibers face in industrial sites (e.g., oil fields, power grids)? How does packaging serve as a “mechanical bridge”?
In industrial environments such as oil fields and power grids, bare optical fibers are highly susceptible to various physical damage risks due to their fragile nature. These risks include:
  1. Mechanical Stress: Direct crushing, sharp bending, and excessive tension can easily break or damage bare fibers, leading to signal loss or sensor failure.
  2. Abrasion: Contact with rough surfaces, dust, or moving parts can cause wear and tear on the fiber cladding, compromising its integrity.
  3. Chemical Exposure: Industrial settings often involve corrosive chemicals, oils, and solvents that can degrade the fiber’s coating and even the glass itself over time.
  4. Temperature Extremes: High or low temperatures, and rapid thermal cycling, can induce stresses on bare fibers, leading to micro-bends or material fatigue.
  5. Moisture Ingress: Water or humidity can penetrate the fiber’s protective layers, accelerating degradation and increasing susceptibility to mechanical damage.
Packaging serves as a “mechanical bridge” by providing a robust external layer that shields the delicate bare fiber from these harsh conditions. Specifically, it acts as a mechanical bridge in the following ways:
  • Load Distribution: The packaging material (e.g., metal tubes, polymer coatings) absorbs and distributes external forces, preventing them from directly impinging on the bare fiber. This ensures that the fiber itself experiences significantly reduced stress.
  • Strain Transfer: For strain sensors, the packaging is designed to efficiently transfer the strain from the monitored structure to the embedded Fiber Bragg Grating (FBG), while protecting the FBG from localized stresses that could lead to inaccurate readings or damage.
  • Environmental Barrier: Packaging creates a physical barrier against chemical agents, moisture, and extreme temperatures, maintaining a more stable and protected micro-environment for the fiber.
  • Ease of Handling and Installation: Packaged sensors are much easier to handle, install (e.g., by welding, bonding, or clamping), and route in industrial settings compared to bare fibers, which require extreme care.
For example, OFSCN offers various industrially packaged FBG sensors designed to withstand such harsh environments. The OFSCN® Alloy Tube Packaged Fiber Bragg Grating Strain Sensor uses a seamless metal tube, eliminating issues like creep from adhesives and providing robust protection for long-term high-temperature applications.
Here are some examples of packaged FBG sensors:
