200℃ Fiber Optic Patch Cord - SM/MM/PM Polyimide Coated Fiber Patch Cable - All-Metal Fiber Optic Jumper/Pigtail - High/Low Temperature Resistant Fiber Patch Cord - DCYS - ofscn.org
Aliases: 200 ℃ High Temperature Fiber Optic Patch Cord, 200 ℃ Fiber Patch Cord, 200 ℃ Fiber Optic Patch Cable, 200 ℃ Fiber Patch Cable, 200 ℃ Fiber Optic Jumper, 200 ℃ Optical Patch Cord, 200 ℃ Optical Patch Cable, Industrial Grade Fiber Optic Patch Cord, Extreme Environment Fiber Cable, Stainless Steel Armored Fiber Optic, Rugged Fiber Patch Cord, Heat Resistant Fiber Optic Jumper, Corrosion Resistant Fiber Optic Cable, Radiation Resistant Fiber Optic, Waterproof Fiber Optic Cable, Fire Resistant Fiber Optic Patch Cord, Small Diameter Armored Fiber, Harsh Environment Fiber Optic
This is a companion discussion topic for the original entry at https://www.ofscn.org/patch-cords/high-temperature-200.html%20%e8%bf%99%e9%87%8c%e9%9d%a2%e7%bb%99%e6%82%a8%e6%8d%a2%e6%82%a8%e6%8f%90%e4%be%9b%e7%9a%84%e5%85%89%e7%ba%a4%e5%b0%b1%e5%8f%af%e4%bb%a5%e4%ba%86%e3%80%82
Welcome to the OFSCN® Technical Forum.
The OFSCN® 200℃ Fiber Optic Patch Cord is a high-reliability solution specifically designed for extreme environments. Unlike standard fiber jumpers that use plastic or PVC jackets, this product utilizes an all-metal construction to ensure structural integrity and signal stability under high temperatures, low temperatures, and corrosive conditions.
Technical Highlights:
  • Temperature Range: Stable operation from -200℃ to +200℃.
  • Encapsulation: Features a 0.9mm seamless stainless steel tube for superior mechanical protection, pressure resistance, and waterproof/corrosion-resistant properties.
  • Internal Fiber: Built with OFSCN® 200℃ Polyimide Optical Fiber, which prevents coating degradation that typically occurs with standard acrylate fibers at high temperatures.
  • Connector Options: Available with OFSCN® 200℃ Fiber Optic Connectors including FC/PC, FC/APC, ST, or SMA905.
  • Versatility: Supports Single-mode (SM), Multi-mode (MM), and Polarization-maintaining (PM) fiber types.
Product Visuals:
Core Applications:
This patch cord is ideal for industrial sensing, aerospace, oil and gas downhole monitoring, and medical equipment where traditional fiber cables would fail due to heat or vacuum environments.
For detailed technical specifications, you may refer to the official product page:
OFSCN® 200℃ Fiber Optic Patch Cord Detailed Parameters
