Aliases: 300 ℃ High Temperature Fiber Optic Patch Cord, 300 ℃ Fiber Patch Cord, 300 ℃ Fiber Optic Patch Cable, 300 ℃ Fiber Patch Cable, 300 ℃ Fiber Optic Jumper, 300 ℃ Optical Patch Cord, 300 ℃ Optical Patch Cable, Industrial Grade Fiber Optic Patch Cord, Extreme Environment Fiber Cable, Stainless Steel Armored Fiber Optic, Rugged Fiber Patch Cord, Heat Resistant Fiber Optic Jumper, Corrosion Resistant Fiber Optic Cable, Radiation Resistant Fiber Optic, Waterproof Fiber Optic Cable, Fire Resistant Fiber Optic Patch Cord, Small Diameter Armored Fiber, Harsh Environment Fiber Optic
This is a companion discussion topic for the original entry at https://www.ofscn.org/ko/patch-cords/high-temperature-300.html
This topic provides technical details for the OFSCN® 300°C Fiber Optic Patch Cord, a specialized optical component designed for extreme thermal environments.
Technical Overview
Unlike traditional fiber jumpers that use plastic or polymer jackets, this product utilizes a specialized all-metal structure to ensure integrity at high temperatures.
- Key Components: It consists of high-temperature resistant fiber (Polyimide-coated), 0.9mm stainless steel seamless tubing, and specialized fiber connectors.
- Thermal Performance: The operating temperature range is exceptionally wide, covering -270°C to +300°C.
- Durability: The seamless steel tube provides high tensile strength, pressure resistance, and protection against rodents and mechanical damage.
Product Specifications
- Standard Diameter: 0.9mm (customizable).
- Fiber Types: Available in Single Mode (SM), Multi-Mode (MM), and Polarization Maintaining (PM) variants.
- Default Fiber: OFSCN® 300°C SM Polyimide Optical Fiber.
- Connectors: Default FC/APC; other types like ST or FC/PC are available upon request.
- Customization: Lengths can be customized from 1 meter to several hundred meters.
Visual Reference
Below are the standard images for this product series:
For detailed parameter sheets or application-specific configurations, please refer to the official product page:
OFSCN® 300°C Fiber Optic Patch Cord.
