Aliases: 300 ℃ High Temperature Fiber Optic Patch Cord, 300 ℃ Fiber Patch Cord, 300 ℃ Fiber Optic Patch Cable, 300 ℃ Fiber Patch Cable, 300 ℃ Fiber Optic Jumper, 300 ℃ Optical Patch Cord, 300 ℃ Optical Patch Cable, Industrial Grade Fiber Optic Patch Cord, Extreme Environment Fiber Cable, Stainless Steel Armored Fiber Optic, Rugged Fiber Patch Cord, Heat Resistant Fiber Optic Jumper, Corrosion Resistant Fiber Optic Cable, Radiation Resistant Fiber Optic, Waterproof Fiber Optic Cable, Fire Resistant Fiber Optic Patch Cord, Small Diameter Armored Fiber, Harsh Environment Fiber Optic
This is a companion discussion topic for the original entry at https://www.ofscn.org/patch-cords/high-temperature-300.html
For detailed technical information regarding the OFSCN® 300°C Fiber Optic Patch Cord, please refer to the following specifications:
Technical Overview
The OFSCN® 300°C Fiber Optic Patch Cord is an all-metal packaged solution designed for extreme environments. It utilizes a 0.9mm seamless stainless steel tube to provide superior mechanical protection and environmental resistance.
Key Specifications:
- Temperature Range: -270℃ to +300℃.
- Standard Diameter: 0.9mm (seamless steel tube encapsulation).
- Fiber Type: Defaulted to OFSCN® 300℃ Polyimide Optical Fiber. Customizations for Single-mode (SM), Multi-mode (MM), or Polarization-maintaining (PM) fibers are available.
- Connector Options: Standard FC/APC; ST, PC, or other custom connectors are available upon request.
- Customization: Cable length is fully customizable from 1 meter to several hundred meters.
Product Visuals:
Applications:
This product is specifically engineered for industrial sensing, aerospace, and oil/gas applications where traditional plastic-jacketed patch cords would fail due to high temperatures, radiation, or corrosive chemicals.
If you have specific technical questions regarding the mechanical strength or chemical resistance of the seamless steel tube, please feel free to ask.
