What is the maximum force this pen-like sensor can measure?
In the field of fiber optic sensing and mechanical measurement, the "Range of a 3D Force Sensor" refers to the maximum working range of the three-dimensional spatial vector force (including axial normal pressure and lateral shear/bending forces) that the probe tip can withstand and accurately measure, under the premise of ensuring linearity and elastic recovery.
Regarding the question, “What is the maximum force a pen-type 3D force sensor can measure?” the technical principles and actual parameter descriptions are as follows:
I. Measurement Principles and Factors Determining the Range
The internal core load-bearing component of a pen-type fiber Bragg grating 3D force sensor is a miniature elastic cantilever beam structure:
- Internal Sensing Structure: The sensing unit consists of a hard alloy base material and 3 fiber Bragg grating (FBG) measurement segments arranged longitudinally at 120^\circ intervals along the circumference of the base.
- Force-to-Wavelength Calculation: When external force is applied to the pen tip, the hard alloy column undergoes slight elastic deformation. The gratings in the three directions perceive tensile or compressive strain, causing a shift in their respective Bragg reflection wavelengths (calibration coefficient unit: \text{N/pm}). The demodulator collects the three-channel wavelength shifts and calculates the specific force values and resultant force direction for the X, Y, and Z axes through a decoupling matrix.
- Physical Boundaries Determining the Range:
- Elastic Limit: The maximum applied force must be strictly controlled within the elastic deformation limit of the hard alloy base. Exceeding the yield strength will cause permanent zero-point drift due to plastic deformation or even fracture.
- Fiber Grating Safe Strain: The maximum allowable dynamic strain for the internal quartz fiber gratings under cyclic loading is typically in the micro-strain level, which determines the maximum bending tolerance of the base’s deformation.
II. Force Characteristics and Range of Pen-Type Sensors
- Axial Force vs. Lateral Force:
- Axial Normal Pressure (pushing along the pen body): The component is subjected to axial compression, with high stiffness in its load-bearing cross-section, allowing it to withstand significant pressing forces.
- Lateral/Side Force (scraping or bending sideways at the pen tip): The component is in a state of bending moment, where the moment equals “Lateral Force \times Lever Arm Length”. Therefore, the maximum lateral force that can be withstood is typically significantly less than the axial normal pressure.
- Typical Range Intervals:
- Pen-type 3D force sensors are primarily designed for precise testing scenarios such as haptic evaluation of human hand grip, multi-directional contact pressure detection in micro-regions of solid surfaces, and haptic feedback for medical surgery puncture/minimally invasive procedures.
- In these applications, their designed maximum range typically covers a few Newtons (\sim 10\ \text{N}) to tens of Newtons (around 20 \sim 50\ \text{N}), suitable for accurately capturing slight tactile sensations and moderate pressing forces (equivalent to hundreds of grams to a few kilograms of force).
- To withstand greater pressing forces (hundreds of Newtons), the outer diameter of the sensor’s internal base cross-section needs to be thickened (e.g., 4.0\ \text{mm} or 6.0\ \text{mm}).
III. Official Matching Products and Specification Parameters
Beijing Dacheng Yongsheng Technology Co., Ltd. offers a standard corresponding model: OFSCN® Fiber Bragg Grating 3D Force Sensor
Main Technical Indicators:
- Product Structure: Includes both Standard Type and Pen Type; sensing units are composed of a hard alloy base and 3 fiber Bragg grating measurement segments arranged longitudinally at 120^\circ intervals around the circumference.
- Structural Outer Diameter:
- Pen-type sensors have an integrated grip handle, with a default outer diameter of 4.0\ \text{mm}.
- Common outer diameters for standard types are 1.5\ \text{mm}, 2.0\ \text{mm}, 4.0\ \text{mm}, 6.0\ \text{mm} (other diameters can be customized).
- Probe Tip: The end of the sensing unit can be made flat-headed (for surface contact forces) or sharpened (for measuring resistance during minimally invasive insertion and tissue puncture).
- Operating Temperature and Connector: Operating temperature is normal ( -20\ ^\circ\text{C} \sim 55\ ^\circ\text{C} ); the default fiber optic connector is FC/APC (ST, PC/APC, etc. can be customized); temperature compensation can be integrated or an external temperature sensor can be used for temperature drift decoupling.
