Adhesive Selection for FBGs
In non-metallic packaging, how do the temperature resistance and hardness of the glue affect performance?
The temperature resistance and hardness of the adhesive significantly impact the performance of non-metallic packaged Fiber Bragg Grating (FBG) sensors, particularly concerning strain transfer and long-term stability.
1. Temperature Resistance:
If the adhesive’s temperature resistance is insufficient for the operating environment, it will degrade, soften, or lose its mechanical properties at elevated temperatures. This leads to:
  • Poor Strain Transfer: The adhesive can no longer effectively transfer strain from the host material to the FBG, resulting in inaccurate or drifting measurements.
  • Creep and Delamination: At high temperatures, adhesives can creep (slowly deform under constant stress) or even delaminate from the FBG or the structure, causing measurement errors and eventual sensor failure. For instance, ordinary adhesive-bonded gratings may fail when subjected to temperatures around 300°C.
2. Hardness:
The hardness of the adhesive influences how effectively and accurately strain is transmitted to the FBG:
  • Too Soft: If the adhesive is too soft, it can absorb or dampen the strain, leading to underestimation of the actual strain or hysteresis in the readings. This reduces the sensitivity and accuracy of the sensor.
  • Too Hard: While high hardness generally ensures good strain transfer, excessively hard or brittle adhesives can introduce stress concentrations. This might lead to damage to the FBG during installation or under significant strain. It is also crucial that the adhesive’s thermal expansion coefficient closely matches that of the FBG and the object being measured to prevent internal stresses caused by temperature changes.
To overcome these limitations, particularly in high-temperature or demanding environments where adhesive creep or degradation is a concern, specialized packaging solutions are often employed. For example, the OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor is designed with full metal seamless tube encapsulation, which eliminates the creep problems associated with adhesives and is suitable for long-term high-temperature welding applications. For bare FBGs, users can select specialized high-performance adhesives tailored to their specific application requirements.
Below are some images of the OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor:
For more details on FBG strain sensors, you can visit:
OFSCN® Fiber Bragg Grating Strain Sensor
